Originally Posted by bhester
Set your idle speed higher something between 750-780 should take care of it.
Respectfully, Bobby, I disagree with setting the idle speed higher on a fixed-pitch RV9A. All fixed-pitch RV9A's that I know of, including my own, have a tendency to float like crazy if landing airspeed is too high or the engine is making more than absolute minimum power during flare and landing. The idle speed should be intentionally set low.
To prevent the engine dying on the runway during roll-out, simply train yourself to push the throttle in a little bit as you slow to taxi speed in order to keep the prop spinning. This is a much better solution than needlessly floating halfway down the runway every landing.
