Hello Gents
I know many of us have installed Infinity Stick Grip in their RV and I'm also in the process in doing the same in my RV-4.
Reading the installation info that came with my Infinity Grip , it is mentioned the following..
''Slot the back side of
your tube beginning
from the top (also the
spacer, if you need
one), .4" to .5" wide
x 1.25" long perpendicular
to the upper boss
hole
for your wires to
more easily pass down''
Is this a requirement to pass the wires on the outside of the stick or to simply facilitate their routing down the middle of the stick??
I did not take my grip apart yet so I'm just asking to be sure I don't give myself extra work if not require..
Thanks you for your feedbacks.
Bruno
rv4@videotron.ca
P.S: If anyone has pictures of their installation, I will be glad to have a look at them if possible.
