11-07-2018, 05:56 PM
Originally Posted by NitroWraith
Maybe I just missed it but...which canopy are you going with?
Originally Posted by nilberg
My bet is on a slider as the shape of the F-757 has a cut out instead of the holes.
Yep this will be a slider. For some reason the tipper just doesn't do it for me. (the manual sure makes the tipper look like a lot more work too)
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
11-07-2018, 05:57 PM
Originally Posted by edbooth
Just a suggestion Jereme, you can mount the rudder cable fairing on the inside of the fuselage.... You only see the part the cable comes through. Just have to massage that hole a little bit. Doing a nice job.
Whoops sorry I missed this post back then good sir. I never thought of putting them guys inside the fuselage. Thanks for pointing this out, I will have to take a look.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
11-08-2018, 04:49 PM
Slider is easy! Bing, Bang, Bomb it's done. For a pro like you, long weekend.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
11-08-2018, 05:14 PM
Now that is what I want to hear! haha unfortunately I can't get to this job until summer.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
11-10-2018, 09:50 AM
That is a good idea. The extra heat of the day helped me. My frame was the hard part the gluing wasn't too bad at all. I haven't done the windscreen yet, I need a little room to finish the panel...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
11-11-2018, 08:09 AM
Well I have changed gears a bit but I'm still getting things done. I decided it was time to do some things in the garage pertaining to the flaps and ailerons since winter is approaching and I can work on those in the house. But first...
My first RV grin! I had to drill some holes on the front deck so I thought why not.
20181104_131705 by Jereme Carne, on Flickr
20181104_131152 by Jereme Carne, on Flickr
I also quickly learned that these vents supplied in the kit are a joke. I'll be going with some Stein vents now. Unfortunataly they aren't cheap!
20181104_145221 by Jereme Carne, on Flickr
What are these you ask? They are aileron stiffeners but I don't see them that way... I see them as 2 hours of deburring.
20181110_154840 by Jereme Carne, on Flickr
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
11-11-2018, 04:08 PM
Fun!
Uhhh.. Did those a few month ago. So much fun! But the flaps are nice part to build that do go together really quickly.
VAF dues paid for 2020
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
11-12-2018, 11:42 PM
Firewall environment
I would like to make some comments based on the front view of your fuselage.
1. You may find it very difficult to rivet the F-7107-L, F-7107-R and F-7108A ribs to the firewall with the engine mount installed. The top two rivets on each rib are OK but the remainder lower rivets are the problem getting a rivet gun into those locations. Ask me how I know.
2. Before installing the front top skin I would suggest you complete fitting all your instruments and components to your instrument panel and back panel. Having the top skin off makes it much easier to complete the wiring as you have better access.
3. Following on from item 2 work out where you want them and then make the the holes you are going to put in the firewall for the engine wiring harnesses (e.g. EGT/CHT, oil pressure and temperature, fuel pressure, magneto leads, etc). I used the Aircraft Spruce 3/4 inch kit P/N: 09-00978 (they also come in 1/2 inch and 1 inch sizes) as they are made of steel and utilise Fire sleeve. Ease of access again is the benefit.
Enjoy the building process and post some more threads showing your progress.
Gordon Griffin
RV-7A under construction
VH-NAK
IO-360-M1B
Catto 3 blade prop
11-13-2018, 06:17 PM
Thanks for the comments Gordon! I am on the same page on 1-3. Top skin is slated to be one of the last things done so that I can do all the wiring in peace.  I'm in the process now of gathering all of the stuff that needs to be placed on the firewall as I am going to fibrax it and attach what I can before I put the mount and engine on. The mount right now is only loosely held on so I can attach all of this stuff. I'm trying to get them ribs to a point where I can rivet them to the firewall. After all of this stuff goes on the firewall I can put the mount on for good. It's mainly there right now as I'm running out of room in my house to store it all.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
12-11-2018, 12:48 PM
Wow this has been a really interesting thread to read. I keep thinking I'd like to build a Vans RV someday (probably a 14). That said, I have zero building/fabrication skills, so it's always been fairly intimidating to me. I'm a mechanical engineer by trade and I've done my fair share of wrenching on motocross bikes (grew up racing), some basic auto work, and plenty of RC airplane building! That said, this is definitely a whole different league! Looks like a lot of fun. I own a Cherokee 140 with my dad and our hangar neighbor is building an RV-14. He showed me some basic riveting work last weekend (riveting, back riveting, nut plates, etc). I can see how you could get hooked on building.
What have been your "must have" shop tools (not aircraft specific tools that you would get in the Cleaveland RV Tool Kit, but stuff like bench grinder, drill press, band saw, etc)?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
