For the most part, compatability is no issue. Most primers that your painter will use will stick to anything but certain plastics and silicone. Whatever you put on will be sanded and the new primer will adhere with mechanical adhesion. There is no cross linking with cured paints.
No matter what you put on, your painter will want to put on another primer coat, so keep your coat thin. Many will not paint it without completely removing what you put on it and charge you for the effort. Most painters won't warranty a paint job unless they did all of the work from the base material up.
It is generally a bad idea to apply a porous primer (typical 2K build primers) that is expected to reside in the elements. It will absorb various bad things from the atmosphere that can be hard remove and create potential contamination that will impact adhesion. Best to stick with an epoxy primer that is not porous.
Larry
