  #11
Old 04-25-2017, 04:54 PM
DaleB's Avatar
DaleB DaleB is offline
Originally Posted by xavierm View Post
cnc router - check out the MPCNC https://www.vicious1.com/
Even the Prusa requires tweaking. The only 'plug and play' one I have tried so far is the Mod-T https://newmatter.com/ but it only does PLA and has a small print area.
Mine was about as close as I would ever expect to get. Eight screws to bolt the two major subassemblies together, and three cable plugs. It's got a proximity sensor for assisted bed leveling and I had it printing in less than half an hour, I think. I do need to get a glass bed plate for it though...
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 04-25-2017, 09:13 PM
JordanGrant's Avatar
JordanGrant JordanGrant is offline
Default Prusa as well
I'm running a Prusa i3 Mk2 from the kit (about $800 w/shipping). I started with a Printrbot Simple Maker Edition (about $400). I started using Autodesk Fusion 360 before EAA did their awesome thing with SolidWorks, so I'll probably stick with that. Fusion 360 is also free for hobbyists. I slice with mostly with Cura and Slic3r, although I've tried some others. 3D printing is totally a fun edition to your skillset after/during an airplane build. It does take some time and learning, but if you're interested in it, it's worth the price of admission for these sub-$1000 printers. FWIW, my 7-yr-old daughter can design and print simple things all on her own without Dad's help (could do it when she was 6), so you can figure it out with a little help and instruction.
Jordan Grant
RV-6 N198G
Monthly donation started Mar '20
Old 04-26-2017, 10:31 AM
Tom Gan Tom Gan is offline
if you go the kit build route I highly recommend the PRUSA . I started with no knowledge other than reading websites. I've learned allot about how the components go together both hardware and software as well as calibration. The kit and instructions are very good quality and easy to understand for a newbie.
I also have built the MPCNC and have been experimenting with that as well. You can purchase the plastic online or print them yourself. Similar components used but very different way of thinking v.s. true 3d printing. Have made some routed wood signs thus far and having fun experimenting with just an inexpensive Dewalt cut out tool.
Been considering building a third machine for Plasma cutting since I have all of the welding equipment but the cost goes up allot due to needing a stronger axis and plasma torch control components.
Anyone out there with experience with building a Plasma cutting machine?
RV9-A QB
http://www.mykitlog.com/tomgan
Old 04-27-2017, 08:03 AM
Snowflake's Avatar
I'd be interested in hearing why... One of the benefits of the PRUSA in my mind was that it didn't use the glass plate. The material it comes with seems (from reports online) to be superior for build adhesion with minimal fuss...
Rob Prior
