A couple of thoughts...
Did you lubricate the tailwheel post?
Are the springs just a bit lose? Mine drape down a good bit.
Also, I used eye-bolts to secure the tailwheel springs to the rudder bottom and to the steering arm.
(Click to enlarge)
On the rudder steering horns, the holes are drilled out and eye-bolts are inserted pointing down. The springs are then attached to the eye-bolt with the steel clip that would normally attach the spring to the aluminum arm.
The advantage here is twofold; one, the spring is almost horizontal and should be out of the way of the rudder bottom.* Second, when the spring starts wearing away at the attachment points, the Eye-bolts are easy to replace.
This was not my idea, it was in one of the OLD RVaitors, which are good reading.
Parts List
Qty___Part
_4____Eye Bold Drilled AN42B-5
_4____AN365-1032 nylock locknuts
_4____Washer AN960-10
_2____Cable*Shackles AN115-21
_2____Bolt AN3-6* (Drilled shank)
_2____Castle nut AN310-3
_2____Cotter pins
