Old 04-26-2017, 10:34 AM
deek deek is offline
Originally Posted by pilotea View Post
Still haven't worked out why the LSE must have a 20 degree timing when the mag has 25, if I turn my slick off in flight, I have an RPM drop , the idea of firing two spark plugs at the same time (as with two mags) must give a power advantage, I don't have that advantage at the moment., even in idle the RPM's goes down when on the LSE only, and according to the LSE instructions, I should have a higher RPM with the LSE. It runs smooth though.
With 10:1 you might want to retard the mag a few degrees and realize lower CHT's. A lot depends on how you fly it: high with low MP, low at high RPM and high MP, etc.
There are several Lyc models that were originally certified at 25*BTDC but later "suggested" the timing be retarded back to 20* BTDC. Someone more knowledgeable than me can advise if the 5* timing retard was a requirement via SB, or simply a bulletin or SI. Klaus is quite approachable on the timing topic if you e-mail or call him, but be prepared by carefully reading his instructions first and expect a pitch to dump the mag for a second LSE :-)
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 04-27-2017, 07:40 AM
Robb Robb is offline
My 0360 in my 7 has 10.5 to one. According to Penn it has a beefier crank. I have e mag and p mag ignition along with fuel injection. It pulls HARD on take off especially at sea level. I have zero detonation issues and love the set up. Typical speed I see is 168knots tas at 9gph
