  #11
Old 04-22-2017, 06:44 PM
BillL BillL is offline
Default Before you reassemble . .
Originally Posted by erich weaver View Post
Per the other thread yesterday, no luck fishing out Pmag clamp so dropping sump is the price I pay. Planning on replacing all paper gaskets and rubber intake sleeves as advised but metal exhaust flange gaskets all look good so thinking I can keep those?
A few exhaust nuts awere tough to get a socket on but got a extra thin walled socket n finally got the last one off. Ball joints on exhaust seem pretty frozen despite my occasional dose of mouse oil over the years. At least they are frozen in the right orientation.
Erich
Now might be a good time to free up the ball joints. I put nickel based high temp anti seize on mine. Not running yet, but it won't evaporate like mouse milk. They are hard to hold, I put two 2" bolts through the flange holes and sat it on the vice and clamped the bolts. It made a good platform for exercising the joint.
Good luck on the sump and extraction.
Bill
RV-7
Lord Kelvin:
Old 04-22-2017, 07:16 PM
erich weaver's Avatar
Woohoo! Sump is off, and Pmag clamp was inside. That's a relief.
Got the exhaust ball joints freed up as well.
Feeling better about things.
Where do you suggest I order sump gasket, intake gaskets and the rubber sleeves for the intake tubes? Guessing ACS doesnt carry this stuff. Could likely get from Aerosport Power but is there something quicker stateside?
E
Old 04-22-2017, 07:44 PM
Michael Burbidge Michael Burbidge is offline
Default AeroInStock...
I've had success getting this kind of stuff from http://aeroinstock.com/. AircraftSpruce does have intake tube gaskets. Don't know about the others.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 04-22-2017, 07:54 PM
AX-O's Avatar
AX-O AX-O is offline
I just ordered 2 from aircraft spruce. They have the Superior gasket.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 04-22-2017, 08:54 PM
jrs14855 jrs14855 is offline
Default Gaskets
Aircraft Spruce doe have all the gaskets.
Old 04-23-2017, 04:43 AM
Here's a pic of inside of sump with that little booger Pmag clamp as I found it
Although I drained the oil there was still a thin layer on top of the clamp part that made it difficult to identify with a borescope before removing sump
Erich
Old 04-23-2017, 07:36 AM
AX-O's Avatar
Welcome to the club. I did the same thing with my PMAG clamp about 3 years ago. It hurts now but you will be telling some poor soul the story on VAF years from now because they just did it and their world just collapsed.
Part number from spruce 08-11835 http://www.aircraftspruce.com/catalo...or08-11835.php
You may want to use Loctite 518 on the gasket.
Axel
Old 04-23-2017, 09:29 AM
Thanks for the link Axel. That certainly looks like the right sump gasket, although my engine was built from ECI parts rather than Superior. Are they likely to be identical?
E
Old 04-23-2017, 05:32 PM
AX-O's Avatar
Same thing.
Axel
