  #21
Old 07-06-2017, 02:45 PM
Sig600 Sig600 is offline
Someone smashed your lower cowling
Like to see more pictures of the cowling work that was required.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 07-06-2017, 08:40 PM
Flandy10 Flandy10 is offline
Default Cowling Modification
So, how do you take a standard Van's cowl and transform it into something that will work with a turbo charged, intercooled diesel. Have you got 8 months- Lets start with the new requirements- 15 inch spinner, intercooler, oil cooler 2.5 times standard size, and others.
Start with the spinner change.
Another reason for the spread, this high pressure fuel line (5,000psi+) made contact with the original cowling
Not anymore
Repeat with bottom cowl and throw in a large amount of expanding foam- fun stuff
Shape
Glass
Remove old lower section and graft on new
And that's just the beginning.....
Scott Flandermeyer
Rv-10 TDI 300 hrs
Fayettevile, GA
2020 VAF Donation complete
Old 07-06-2017, 09:58 PM
kgood kgood is offline
I'm jealous! Can't wait to hear more. It has been a lot of work, but someone's gotta do it!
Kurt
Old 07-07-2017, 02:14 PM
Originally Posted by Flandy10 View Post
Here are a few pictures of the installation.
I'm assuming one of these is the oil cooler, the other is the intercooler? Any problems on either with such a huge divergent opening of the plenums?
I'm a big fan of the potential for diesel... really cheering for you on this one (because I want to plagiarize it).
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 07-07-2017, 04:27 PM
The intercooler is on the right and the oil cooler is on the left.
The ducting is working pretty well, but with anything, there is room for improvement during the hot summer days.
Scott Flandermeyer
Rv-10 TDI 300 hrs
Fayettevile, GA
Old 07-08-2017, 01:15 PM
Default More Performance Numbers
G3x recorded 1:47 total time. I figured airborne 1:34 and total burn per the truck meter---12 gallons. Back on level ground in hangar, I sticked the tanks to verify fillup- needed another .5 gallon in one tank. So--12.5 total burn. Fuel burn at 12500 was between 7.5 and 8.0 GPH
Flight profile--climb to 5500 till clear of Class B then continue to 12500. 30 min max cruise. Decided on way down to stop every thousand to check speed numbers.
The following numbers were taken from the data file- let speed stabilize and eyeballed an average- Not the fastest and not the slowest--trying to be honest with the numbers.
Altitude ----IAS ---- TAS ---MAP
12500------127----157-----57
10500------128----154-----60
9500-------135-----158-----60
8500-------136-----158-----60
7500-------132-----151----61
6500-------135-----151----61
5500-------151-----167----76
4500-------155----168-----76
Why the big increase in MAP below 6500? The short version is ----The turbo on this pre-production engine didn't come with a speed sensor (and no way to retrofit one either). So to allow operations above 6000, CMI felt it was prudent to limit the MAP to the "B" model power numbers to prevent overspeeding the turbine.
There is one more test planned---side by side flight with a standard -10 to compare performance numbers.
Scott Flandermeyer
Rv-10 TDI 300 hrs
Fayettevile, GA
Old 07-08-2017, 03:27 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Smile
Looks like pretty good total burn for that mission profile. Around 25-30% lower volume burn per hour in cruise against a well sorted injected 9 to 1 CR Lyc 540 running LOP with EIs. About 12-15% lower burn per unit fuel weight.
Most reports seem to show 9.5-12 gph LOP on injected 540s, depending on power settings but I'd invite any RV10 guys to weigh in with your numbers for comparison.
In cruise at least, a solid $15+/hr. cost savings using the average prices here: http://www.airnav.com/fuel/report.html Jet vs. 100LL.
The side by side will show the true fuel cost delta for for the complete mission. That will be very interesting. Hopefully you'll be comparing with an injected Lycoming with EIs running LOP, not a carbed one running ROP...
I'm curious as to what sort of fuel burn and MAP you're seeing in the descent?
I appreciate the amount of work that went into the installation. Kudos there. Cool project!
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 07-08-2017, 04:37 PM
Default Descent planning
Ross,
On this flight, I just maintained the cruise power and set up a 750fpm descent. From 12500 down to 6000, those MP settings equate to about 155-160Kias descent. I'm going to make a guess that with fuel flow for 57"MP at about 8gph, it is approaching 8.5 at 62"MP. Again, just a guess.
The ability to accurately measure FF over the entire RPM range has been an exercise in futility. The Red cube system cannot read the idle flow rates (I see 2.5 to 45gph regularly during taxi- it should be >.5gph) and its inflight variation can be +/- .5 to 1 gph at any given second. So I'm looking for a K-factor that comes close. I have looked at other systems that work accurately with diesel generators or boats, but nothing is compatible with aviation's analog inputs.
Scott Flandermeyer
Rv-10 TDI 300 hrs
Fayettevile, GA
Old 07-08-2017, 05:25 PM
rv6ejguy's Avatar
Ross,
Interesting. Surprised at such high MAP in the descent. Certainly different from a turbo SI engine. Is there a minimum MAP they recommend in flight to keep the fires lit?
They don't have any FF signal available out of the FADEC?
Old 07-08-2017, 05:28 PM
rv7charlie rv7charlie is offline
Hi Scott,
Have you looked at the older style FloScan sensors? They make them specifically for diesel engines (marine), and as far as I know, their K factor is similar to the gas version. Therefore, they should work with your gauge/EFIS, since (again, as far as I know), the FloScan & red cube sensors are supposed to interchange.
Just a thought,
Charlie
http://www.floscan.com/dnloads/floscanfinal.pdf
