  #31
Old 06-24-2018, 08:48 AM
Captain_John's Avatar
Walt, use of installed equipment needs to be evaluated. If the installed equipment isn't functioning, it can't be evaluated. I have the LOD with the reason on it to show you if you still find it strange. Trust me, it's a thing!
Thanks for your input though!
On a different note, I did look at my data and in the Autopilot State column it has two strange lines of code. If anyone knows what Fail/abnormal disengage/00000004 and Fail/communication fault/00000005 means, I would be interested in knowing.
Steve from Garmin, the data is in your inbox.
Thanks again!
CJ
The experiment works!
Old 06-24-2018, 09:19 AM
SMO's Avatar
SMO SMO is offline
I would suspect the CAN bus. I had a similar intermittent problem. I ended up redoing all the connections - I found one connection where I had sliced into one of the wires when stripping the outer sheath, and one of the fine wires from the shield was shorting there.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 06-25-2018, 11:50 AM
Dugaru's Avatar
Dugaru Dugaru is offline
Originally Posted by Captain_John View Post
Yesterday in the final throws of my IFR checkride, during the flight portion (of course) of the test my ap disconnects. I presumed that I hit the trim buttons, so I re-engaged it. After about a couple of minutes it disengages again. This happened several more times and I was unable to complete the exam. As you can imagine, this was somewhat discouraging!
I was the guy who started this thread about the servo issue. What you describe does not sound like my servo problem, which annunicated with a big black box on the screen.
It does, however, sound like the problem I had just a few weeks ago, after my autopilot had been working correctly for months:
http://www.vansairforce.com/communit...d.php?t=161284
Did you also get a red "AFCS" failure alert?
I've been logging data religiously since my incident but thus far it's been working without a hitch. I'll be interested to see what you come up with.
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2020 Dues Paid
Old 06-25-2018, 06:45 PM
Well, I got no indication of any failures. No red x's or anything. It just bugged out with the trlple tone.
I will keep you posted with what I discover.
Really looking forward to getting this sorted out!
CJ
Old 06-26-2018, 06:54 AM
Dugaru's Avatar
Your error message seems to be similar to what was described in this thread:
http://www.vansairforce.com/communit...d.php?t=157633
So maybe there is a new software problem. On the other hand, I'm running mine from a G5 with a GMC307 panel, so there are a lot of variables that are different between yours and mine. Who knows.
I was able to get mine going again after popping the autopilot circuit breaker and resetting it, and it worked after that, but I haven't been able to fly it much lately.
I am envious of your triple tone! I would love to have an audio warning of the autopilot disconnecting. I get only a little flashing yellow square (and sometimes the AFCS warning) on an attitude indicator that is my backup AI, so an uncommanded disconnect is easy to miss, especially in cruise. I think this is a drawback of a G5/GMC307 installation that appears to have been remedied with the GMC507.
Garmin folks: is there an upgrade path from the 307 to the 507? I think the warning tone would be worth it, although obviously it would need some additional wiring to the audio panel. Or could you do a software upgrade that flashes the whole G5 screen yellow (or something similarly "alarming") when the autopilot disconnects?
N929JA, 2007 RV-9A
2020 Dues Paid
