Old 04-18-2017, 07:35 AM
DanH's Avatar
DanH DanH is online now
Default "Continuous Operation"?
Can anyone point to an official Lycoming definition of continuous operation?
I suspect a lot of us assume it means "more than five minutes", but consider, for example a propeller limitation. Running a prop in a resonant range for more than a few seconds is not a good idea, as stress cycles are cumulative.
(Yes, I know prop limitations are not set by Lycoming. It's an example).
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-18-2017, 07:55 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Interesting you bring the prop thing up.
The IO-540-K1G5 has a TO rating of 300 hp at 2700 rpm
MCP with 2 blade prop is 294hp at 2600
MCP with 3 blade is the same as TO power rating- 300hp at 2700.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
