Originally Posted by dan
Check your calibration. Could be that it's off...much simpler than anything mechanical. Dip your oil temp probe in 212F (boiling water) and see what your gauge reads...
...been there twice and it is right on.
With the SW 8432R completely blocked off, oil temp struggles to get up 150 on a 20F day. It takes 15 minutes to get it up to 100F before take off.
The "vernatherm" (Does anyone know where that term came from? It is not in the Lycoming lexicon of words) is a hot weather device that assures oil will flow to the cooler. In cold weather it may as well not be installed, it has no useful function as it does not block oil flow to the cooler.
I am of the opinion if one has good cooling in the summer months, it is way too good in cold weather. The only way to change that is to cut down air flow through the engine compartment.
That issue could be resolved with cowl flaps or a baffle to restrict exit air. Messing with inlet air flow could really disturb individual cylinder head temps and probably is not the way to go.
I keep thinking global warming will return but there is snow in the forecast for today and also Christmas Eve. If it becomes one of those typical freezing rain, turning to snow events so common around here, the issue may be mute. Our field will be closed for weeks. I am beginning to not like a grass runway.
