  #21
Old 04-18-2017, 04:37 PM
John-G John-G is offline
Originally Posted by Piper J3 View Post
Question... Does anyone know the weight of a set of new floats fresh out of the box?
Jim - not sure about of the box, but I checked the weight of both the floats in each carburetor on my engine prior to installing it on the RV-12 firewall. The floats measured in at 3 grams each.
Since you are in the carbs .... make sure the float arms are parallel with the body of the carb when the carb is held upside-down. It is possible for otherwise good floats to allow excess fuel into the carbs if the float arms are also not adjusted correctly. Visually, they should be parallel ... but there is an $85 gauge that is supposed to be used to make the adjustment perfect.
John
www.dogaviation.com
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 04-18-2017, 05:03 PM
DHeal DHeal is offline
Mine were 2.8 grams dry each out of the box (i.e., 5.6 grams total for the pair).
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 04-18-2017, 05:56 PM
daveyator daveyator is offline
3 grams is about 1/9 of an ounce. Sounds a bit light to me
DaveH
Old 04-18-2017, 06:06 PM
Oooppss! I should have said 2.8 grams each! 5.6 grams total.
Old 04-18-2017, 07:47 PM
Set my mind at rest. Thanks.
Cheers
DaveH
Old 04-18-2017, 07:56 PM
Piper J3's Avatar
Piper J3 Piper J3 is online now
Thank you gentlemen...
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 04-19-2017, 11:23 AM
Bigsteve Bigsteve is offline
I had the same smell on climbout only. Removed the tunnel cover and found real small leak on blue fitting used to connect fuel return line. I had been using some avgas, so trail to fitting was obvious. A & P added microthin washer to fitting and all good. My guess is that during climbout, the gas moved down the tunnel to where the fuel shut-off is and a small opening exists where the handle comes thru that also allowed the vapor to exit. Never smelled gas during long flites, or taxi or landing, only on climbouts. This happened during the time period when we were weighing floats, waiting for new ones, so i thought the smell was float related also.
WB9FZX
Old 04-23-2017, 04:14 AM
Piper J3's Avatar
Update... I bought AC Delco 10-5045 Multi-Purpose Fluorescent Leak Detection Dye and 100 LED UV Black Light Scorpion Flashlight to help locate source of fuel smell. Yesterday I mixed 1 oz. of the dye with 12 gallons of fuel in the tank and flew for half hour. Today I will open all access panels and search for source of leak with black light. The dye fluoresces a brilliant orange color so it should be easy to spot a leak.
Jim Stricker
EAA #499867
Old 04-23-2017, 10:47 AM
RFSchaller RFSchaller is offline
Good luck. I just did the 5 year hose replacement, and I am chasing a coolant weep that equates to 1/2" of overflow bottle level in 12 hours of operation. I put The dye in my coolant Friday and will check with a UV light Monday after 5 hours of flying this weekend.
Old 04-23-2017, 04:33 PM
Piper J3's Avatar
Found the leak with black light and fluorescent dye... works a charm. Two flush rivets at internal strengthening plate on front bottom right side have very slight (miniscule) leak. Real problem is single rivet on top cover plate in rear right corner has enough seepage to wet your finger when you wipe over it. This rivet is leaking when the plane is in a climb and fuel sloshes to the rear.
I also removed cowling to check carb overflow. They are dry as a bone...
Jim Stricker
EAA #499867
