Old 04-13-2017, 12:08 PM
istrumit's Avatar
istrumit istrumit is offline
Default Raising the nose gear on an RV-10
I searched Google and VAF and did not find a simple way to raise the nose gear to change the nose wheel.
For the main gear, I use a 1-1/8 pipe clamp and a standard hydraulic jack. This works great.
But, for the noise gear ?
Any ideas ?
Scott
Scott Martin
N430WP RV-10 - Purchased
Old 04-13-2017, 12:12 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
I have a 120lb chunk of concrete on rollers that anchors a cargo strap attached to the rear tie-down. Winch the strap down and the nose gear comes off the floor.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Auburntsts's Avatar
Any ideas ?
Scott
I use my engine hoist with straps to the engine mount to lift the nose off the ground. Others use the tail tie-down ring and weights or straps to an eyebolt in the hangar floor to pull the tail down and lifting the nose up.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-13-2017, 12:41 PM
Lynnb's Avatar
Lynnb Lynnb is offline
We've done it like this with an anchor attached to the floor of the hanger and a ratchet strap. Actually one guy will lean across the fuselage at the tail and slowly pull the front end up then we just tie it down more than ratchet it. Works really well.
RV-10 in Process
Old 04-13-2017, 01:03 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
This worked just fine for me---and a buddy's 10 before that.
Some folks have expressed a lack of confidence in the lead insert-----use something more secure if you feel it is needed.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-13-2017, 04:11 PM
noelf noelf is offline
On my -6A, I use a scissor jack under the nose gear fork strut nut. This allows me to remove the wheel / tire and to check the breakout force at each annual. This is a very stable method to get the nose wheel off the floor.
Noel
RV-6A N6NF
tip-up
flying
Old 04-13-2017, 06:25 PM
That's how I do it.
Old 04-14-2017, 10:14 AM
istrumit's Avatar
Thats Brilliant !
Scott Martin
Old 04-14-2017, 11:11 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Standard floor jack right under the front of the gear leg works great (I have allow profile race jack)
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Chief
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
Race Coordinator STOL Drag coming to Reno, 2019
"so I got that going for me... which is nice."
Old 04-14-2017, 12:12 PM
rleffler's Avatar
rleffler rleffler is offline
Mine is just a standard four wheel dolly, a sheet of 3/4" plywood, and some concrete blocks. Works great!
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
