Old 04-12-2017, 08:11 AM
Default Installing aft crank shaft plug
Anyone here who has successfully installed the aft crank shaft plug when going to CS prop?
How about a run down on how you did it and the tool used to spread the plug.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 04-12-2017, 08:21 AM
brad walton brad walton is offline
David, I don't have a response to your inquiry. But I have an RV8 io 360 with a Catto prop and I look forward to a performance comparison between your before and after. I hope you will do one.
Old 04-12-2017, 09:36 AM
chrisbryanolsen chrisbryanolsen is offline
Default Tool
See this thread: VAF Thread
Thought I had a picture but can not find it now. The one I made based on the above dimensions worked fine. Made it from wood and the plug drove home with little issue.
Link to some pictures I do have: Prop Swap
Chris Olsen
Chile Flight
N2ZK RV-4 @ KAEG
Dues Paid Nov. 2019
Old 04-12-2017, 10:39 AM
Brantel's Avatar
Brantel Brantel is offline
I used a wooden dowel and cut it so that it would fit around the oil tubes. Used that to get the plug started and mostly seated.
Just tapped it home with a long brass drift pin.
Worked great!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-12-2017, 05:20 PM
Thanks you-all for the info, sounds like is no big deal.
I called Rhonda at BPE this morning, she is sending a plug gratis...thank you young lady, you are the best.
I am very inclined to go forward with this upgrade when all the hoops with FAA medical are hopped through. Big challenge will be thorough eye test of the 25th.
Meanwhile, anyone here a fan of Emmylou Harris? She will be at Ryman Hall in Nashville on May 2. I got one of last tickets in 4th row from stage.
RV-12 Build Helper
RV-7A...Sold #70374
Old 04-13-2017, 05:38 AM
Robert Anglin Robert Anglin is offline
Default Brass or Alumimum
David we have used soft metal driffs to set the plugs as well works fine. They are much like an old expanding freeze plug in an automotive engine block, not hard to set, just a good hard whack with a two pound hammer.
Hope this helps, yours, R.E.A. III #80888
Old 04-13-2017, 05:45 AM
trifield trifield is offline
Default Crank plug
David I had to trim my plug to get it past the oil tube ,getting the pieced old plug out was the hard bit. Enjoy your c/s ,I am.
Old 04-13-2017, 09:35 AM
Allen Barrett called about installing that plug when assembling the engine. We decided it made no sense to install it and punch a hole in it, so it was not installed.
I imagined getting one out could be a challenge.
Thanks to all for info.
RV-12 Build Helper
RV-7A...Sold #70374
