Kent:
I sent you an old 1961 Lycoming Curve No. 10156 in PDF format to your private email address. It is for the 150 HP 320 but is typical on what the limiting manifold pressure should be for continuous operation.
You should have graph's in the back of your Lycoming Owner's Manual.
If you do not have a Lycoming Owner's Manual, you should be able to purchase one form Lycoming for about $20.
http://www.lycoming.textron.com/supp...rs/SL114AM.pdf
I now have 1,977 hobbs hours on my RV-6, O-320, Hartzell. I like to run over square. See article that I sent to your private email. My personal limit is to avoid more than 3 inches over square for continous operation. I do not worry about a temporary over squre of 6 inches. My SOP is to push the prop in to HIGH RPM on short final. I do GUMP twice in the pattern. Once on downwind then again wings level on final.
I have an old 1961 11 X 17 copy of Curve No. 9541-C for the 150 HP 320 that has more info than the chart I emailed. I can scan / send it if you like.
Hope this helps.
