Old 01-31-2007, 04:47 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Exclamation Report: "Nutserts"
I needed a way to mount the upper intersection main gear fairings and regular nutplates looked like a POTA. I used Nutserts from Aircraft Spruce and got their inexpensive tool with them. They take a 1/4" hole for a #8 screw sized Nutsert. I drilled undersize and reamed to 1/4" for precision. The factory sent me a .pdf which I will share on request. The .pdf has much more information than in the Spruce catalog.
Pro: They work as advertised; they are small and light; inexpensive, sufficiently strong for the application; can take all the torque they need to take. Blind hole and closed end types also available. Can be a terrific work-around where there is insufficient room or access to install a nutplate. I suppose one could use a thread locking compound to make up for the lack of nutplate type locking. I wonder how they'd be where a tapped hole was stripped, like on the tip-up roll bar? I hope I never need to find out.
Con: Don't use them if you need the locking behavior of the nutplate or the extra strength. They are a little hard to get started when installing with the supplied allen wrench. Need about 1/2" clearance behind. There is a little flange on the front side about .020 or a hair less in thickness. The directions say to have the top material ride on the flange to prevent pull-out, so except in an application like these fairings, that could be an issue. A true nutplate is only on one side and the top material sits flush. You have to be careful to keep it parallel when compressing it.
I can't compare to rivnuts because I've never used rivnuts. The Nutsert has little teeth and grips the inside of the hole quite well when it swells up as you compress it. It can be used in material as thin as .030" and can go much thicker, all with the same size Nutsert. As thickness of material increases, you go to a slightly larger hole.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 05-18-2008, 10:29 PM
n505at n505at is offline
Default Nutsert Installation
I plan on using nutserts to attach the upper gear leg fairing to the fuse. I came across this article on installing nutserts. It worked well on .063 and .025 alum. with 8-32 nutserts from ASC.
www.318ti.org/notebook/nutserts/
Roy Samuelson
RV7A
Oakland CA
Old 05-18-2008, 11:48 PM
Rivethead Rivethead is offline
Are nutserts anything like rivnuts?
Old 05-19-2008, 01:26 AM
moodyjr moodyjr is offline
I've used a heap of nutserts on various aircraft. The have a fairly loose thread &
I've lost a lot of screws (but, fortunately, nothing else).
I would not use them without loctite or silicone sealant on the threads to retain the screws.
John Moody
RV-8A
Old 05-19-2008, 05:33 AM
Mel's Avatar
Mel Mel is offline
In my opinion, they work better than rivnuts. I've used them on intersection fairings. Certainly wouldn't use them anywhere structural.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-19-2008, 12:00 PM
oops I missed that last line. Anyone have a picture of a nutsert?
Old 05-19-2008, 01:35 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default I have used these---------
http://www.imperialinc.com/ThumbJpeg...eight=110&NC=y
Used this kind----they make more than one style-----with success in the past.
NOT on aircraft though , (nor would I consider them to be of much use in metal sheets less than .090" or so). We used them extensively on fire engines for mounting accessories.
Look here http://www.imperialinc.com/grp270.shtml
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-19-2008, 03:54 PM
hevansrv7a's Avatar
Default follow up
I used them on the upper main leg intersection fairing. Some stripped out, some held. Would not use them in that context again.
Old 05-20-2008, 09:03 AM
AllanC AllanC is offline
I've used the 'nutserts' from McMaaster-Carr, with their rivet gun like tool for inserting them, and found them convenient and quick and easy to use. As far as stripping threads are concerned, I'm sure there are different qualities, and materials, and I know that McM have both aluminum and steel. I have tried to strip the steel insert threads with a screwdriver by hand, and found it virtually impossible. However, this type are a little harder to set.
They also have the steel types with a serrated grip area, and these are also almost impossible to have them lose their grip in al, as they slightly deform the gripping surface.
