Originally Posted by Charles in SC
Can someone point me to a simple explanation of ADS-B and how to figure out what I will need to be legal? It seems that the more I read the confuseder I get.
If you never fly where mode C is required (over 10,000', class b and C, etc) then nothing is required. Otherwise, by 2020, you have two options:
1. Mode S-ES transponder plus an "approved" position source. "Approved" means it carries the appropriate TSO, or the manufacturer says it meets the TSO performance requirements. One of the manufacturer's must also state that the two boxes will properly work together.
2. UAT transmitter plus approved position source. Many UATs come with the position source built in. Some also have ADSB-in as part of the package.
ADSB-IN is not required. But if you want it, start by considering how you will display the traffic and wx data.
