Old 01-31-2007, 02:11 PM
scard's Avatar
scard scard is offline
Default Ignition wire insulators on rear baffle
Does anyone remember if the plastic wire insulators on the rear baffle came with the baffle kit? Or, where do they come from. I don't know if I had them and can't find them or what. If you have two that you don't need, I sure could use them. They should be easily dropped in an envelope.
Scott Card
CMW E-Lift
Old 01-31-2007, 02:27 PM
scard's Avatar
Ok, I'll answer my own question. Ignition baffle seals don't come with any kit. It looks like the nice ones can be sourced from ACS:
here
Scott Card
CMW E-Lift
Old 01-31-2007, 02:58 PM
RV8N RV8N is offline
Yep, that's where I got mine. Only problem with mine is that the baffles are painted red and the insulators are kind of a baby blue. But hey, they work.
Karl
RV-8 #80240 SOLD
1999 BMW R1100RS
Old 01-31-2007, 03:47 PM
erich weaver's Avatar
Is there any advantage to using these over a simple hole in the baffle with rubber grommet for each spark plug lead?
erich weaver
Old 01-31-2007, 03:56 PM
Ironflight's Avatar
VAF Moderator / Line Boy
erich weaver
Erich,
The problem with a grommet is that if the hole in the grommet seals nicely on the plug wire, you'll never get it over the end of the wire, unless you split the grommet, and then use lots of RTV to keep it in place and sealed. The diamond-shaped units are two-piece, so they go on real nice. My old Grumman had grommets, and they got ugly real quick.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-31-2007, 04:21 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Mine came with the engine from Lycoming. I got some amber colored ones that worked very nicely. They were a two piece interlocking affair.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 01-31-2007, 04:52 PM
Default rubber grommets?
Paul:
Well, I have small rubber grommets that fit nice and tight without any splitting necessary. I think maybe what you are trying to tell me is that thd grommets wont go on the leads AFTER you have installed the hardware at the ends that connect to the plugs and the electronic ignition modules???
If thats the case, then I think my only concern is that with my rubber grommets, I cant completely remove a spark plug lead without either removing the baffle section with it, or alternatively, removing (and ruining) the hardware at the ends of the leads. These are both undesirable, but then again, I dont really forsee changing my spark plug leads out. Should I? Couldnt be too much work cutting a bigger hole in my baffles and using the ACS insulators, so I would just as soon do this now if its worthwhile.
Hope you can follow this ok.
thanks
erich
Old 01-31-2007, 05:13 PM
Ironflight's Avatar
Paul:
thanks
erich
We are exactly on the same page Erich - if you have the grommets on already, then my comments about not getting them past the end hardware is irrelevant. As long as you can get the grommets in the holes in the baffles, you should be fine. As far as having to change harneses....I think I went through two sets of Mags on my Grumman in the life of the engine, and when I changed Mags, I put on a new harness because it came free in a one-time-good-deal with the new mags. I've never had to change a harness because of a problem with one. Of course, YMMV!
Good luck,
Paul
Paul F. Dye
Old 04-16-2007, 08:25 AM
lrfrey lrfrey is offline
I looked at the wire seals at ACS that were mentioned and would like to use them, but the only size they list are 5 MM. My plug wires measure 7.5 MM.
Will the plug wires compress enough to fit in the seals or can the seals be drilled out to 7 MM or am I missing something (as usual)?
Just another puzzlement!
Thanks, Larry
Old 04-16-2007, 08:54 AM
scard's Avatar
I reamed mine just a bit for a correct fit on larger plug wires.
Scott Card
CMW E-Lift
