04-05-2017, 06:10 PM
Trim tab fiberglass tips???
I'm finishing up on the empennage kit for my RV-8 and I have saved the trim tab for last, as I have heard that I can be pretty challenging to get all the tabs evenly folded over, bent, etc.
Has anyone cut off the tabs that get folded over on the trim tab ends, and instead, close off the ends with fiberglass, similar to the inside of the fiberglass tips on the horizontal and vertical stabilizer?
Also, can this be done on the left elevator skin, instead of folding the two tabs over that run parallel to the trim tab?
04-05-2017, 06:31 PM
I followed the plans and did not have any issues making the trim tab. Go slowand you should be fine.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
04-05-2017, 07:05 PM
Either
I followed the plans and had to order a second set of trim tab parts. I would be tempted to form ribs instead.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
04-05-2017, 07:12 PM
I've never seen fiberglass but I have seen where people cut off the tabs and fashion a rib to install. Similar to the aft few inches of the outboard elevator rib. If I were to do it again that is what I would do. Took me 4 tries on my first build, one try on my -8 build, but it's not as perfect as my -9 was. It's all about the clamping blocks.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
04-05-2017, 08:06 PM
It took me two tries to get something I was happy with. Make sure you have the blocks in the correct position and they are clamped securely. If they move then reposition and reclamp then continue. Take your time and life is good.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
04-08-2017, 10:29 AM
The end closeouts of the trim tab are a structural member of the trim tab.
Do you have the skills and knowledge of working with composites to know that what you install in place of the bent tabs will provide the same strength and stiffness in the tab that the bent tabs would have? If not, then you would be raising the "experimental" rating of your airplane a notch.
Scott McDaniels
Hubbard, Oregon
