  #21
Old 02-01-2007, 10:27 AM
kentb's Avatar
kentb kentb is offline
Cool Nibbler for me to...
Originally Posted by Rick6a
Mark,
Thanks for the excellent tip. Personally, having never considered nor used a hand nibbler...sometimes you just know instinctively a real tool winner when you see one. I'll be picking up my copy real soon. Thanks again.
I used my nibbler on my panel and for my wing skin light. It works great. The panel was a little thick but for fine cuts it was the right tool. I also used a jigsaw with a fine blade on the panel for the ruff cuts.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 02-01-2007, 03:02 PM
brian's Avatar
brian brian is offline
Default nibbler work
The nibbler made this defroster cutout easy:
Mark
Hey, that is some nice, clean work, Mark!
brian
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
Old 02-01-2007, 03:26 PM
Lars Lars is offline
Originally Posted by Mark Burns
I have a regular variable speed "corded" dremel. I've used it very little on the RV project. Not real sure why. I think it's because it's noisy and it usually throws all the dust right in your face. More times than not for me I just can't hold it in a position that will allow me to see what I'm doing and not get sandblasted in the face. Maybe I need some schooling.
I prefer to drill the corners with a unibit and then use a nibbler.
The nibbler reminds me of the old Pac Man game. If you don't have one, get one. Usually they are less than $20.
Mark
You just cost me 20 bucks. Yet another tool I need
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 02-01-2007, 11:24 PM
osxuser's Avatar
osxuser osxuser is offline
To me, the pencil die-grinder is just a Pnematic dremel tool.... takes all the same attachments.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 08-20-2009, 04:24 PM
Michael Burbidge Michael Burbidge is offline
Default What kind of file
What kind of round file did you use to smooth the corners for the duckworks light cutout?
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 08-20-2009, 05:12 PM
rbibb's Avatar
rbibb rbibb is offline
For cutting out holes in aluminum sheet one option I used was a router.
It had to be a situation where I could clamp thing properly but a small router (laminate trimmer type) with a carbide blade does great work on thin aluminum sheet. For straight lines if you can clamp a piece of bar or angle stock as a guide the laminate trimmer blade will cut a great straight line.
I've even made templates from thin plywood or masonite sheet to cut other shapes.
I read once that this was the basic technique used to cut the window openings in the Lockheed Constellation.
As with other methods eye protection is mandatory. Use the goggle type eye protectors as the chips really fly and will find there ways behind any type of safety glasses that are not enclosed on the side.
It won't work in a lot of situations but where it will it produces a nice an edge as if you CNC milled it. Which, come to think of it, you did, the C being your noggin.
Old 08-20-2009, 05:22 PM
C-GRVT C-GRVT is offline
Default get an assortment
I suggest that you go to a hardware store and pick up a few round files with different radii, and use the one that most closely matches the final radius you want, so, for the landing light cutouts, a file with a fairly large radius.
Another tool not mentioned that is great for cutting aluminum sheet in some situations is a coping saw with a diamond blade - cuts fast and with great control.
Bill Brooks
Ottawa, Canada
RV-6A finishing kit
Old 08-21-2009, 12:24 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up Your local Hobby Shop...
Originally Posted by Sam Buchanan View Post
There are at least two types of cutoff wheels available for the Dremel. The thinnest ones are indeed very fragile and grenade with little provocation. There is another fiber-reinforced disk that is much more durable and the kerf is only a little larger. But these disks can tolerate more abuse and are much more practical to use. Both are used with the same mandrel.
And has been stated---Wear Eye Protection!
...should have a House of Balsa cut off wheel. It's kerf is the same as the fragile Dremel wheels and the 2 inch diameter makes it easier to use - less need to tilt your Dremel tool body to clear the surrounding surface. It's also pretty close to indestructible.
http://www3.towerhobbies.com/cgi-bin...?&I=LXM409&P=0
AFAIK Dremel does not make a large diameter cut off disk...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-21-2009, 11:46 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
If you're not doing the cutting on the airframe, a mill works quite well...
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
