Old 03-31-2017, 04:14 PM
Greenley's Avatar
Greenley Greenley is offline
Default Tosten CS-8 drawing needed
Looking for a drawing if one exists of the tosten CS-8 grip to use on my panel to label the buttons.
Bill Greenley
My RV-10 is now travel, watch out world!!!!!!
Old 03-31-2017, 04:47 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Kevin would be the best to contact for production quality but I can get you something that will work fine. Do you want a drawing file or an image file?
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-31-2017, 04:48 PM
Greenley's Avatar
Drawing preferred, but can work with either.
Bill Greenley
Old 03-31-2017, 04:51 PM
I can send you a .dwg (autocad) file if that works for you.
Carlos in Arizona
Old 03-31-2017, 05:24 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Question A copy here too please
Could either of you send a copy to me as well?
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 03-31-2017, 05:33 PM
Chuck, check your PM's.
Carlos in Arizona
Old 03-31-2017, 05:47 PM
cdeerinck's Avatar
Default Fast
Replied in PM. Thanks for the quick response!
~Chuck
DG-800S Sailplane
84CX Reserved
Old 04-01-2017, 09:22 AM
Snowflake's Avatar
The Tosten website has a "user manual" or "installation" PDF that has a line drawing of the grip on it. I planned to bring that into an application like Adobe Illustrator ($$$) or Inkscape (free - www.inkscape.org) and delete everything but the grip drawing, then use the same program to label it as needed. I just haven't done it yet, despite having installed the Tostens a couple of years ago... :P
Rob Prior
Old 04-01-2017, 10:57 AM
cdeerinck's Avatar
Post Here is one
Here is an Autocad file that I put together based on what pazmanyflyer sent me, and more from the Tosten site. I added my labels, but that is an easy edit in Autocad.
https://www.dropbox.com/s/4em7lw4bj6...abels.dwg?dl=0
~Chuck
DG-800S Sailplane
84CX Reserved
Old 04-04-2017, 09:31 AM
Greenley's Avatar
Thanks for help and pictures. Here is something I made from these resources to try and be compact yet document the stick functions. I am planning to put this on my panel as a reference.
Bill Greenley
