Old 01-30-2007, 09:31 PM
pilot28906 pilot28906 is offline
Default Newbie Dimple Question
I have been practicing some drilling, deburring, and dimpling with some scrap pieces that came with the Emp. kit. I have drilled a nice row of holes with a #30 drill bit, deburred them, and dimpled with 1/8" dimple dies using my DRDT2. However, my Cleco's will not work (copper color) after the dimpling. I think the dimple dies should come tight together at the bottom of the stroke. Is this correct? Also, how much is the hole supposed to open up after dimple? I havn't measured, but the hole after dimple is larger than after drilling. Should I open up the dies at the end of the stroke or tighten them closer at the end of the stroke? Any suggestion would be appreciated.
John
Old 01-31-2007, 12:49 AM
dan's Avatar
dan dan is offline
You want the dies to close at the end of the stroke for as crisp a coining effect of the aluminum as possible. With a DRDT-2, there's basically no such thing as over-dimpling.
Clecos...not all brands are created equal. Some have a slightly narrower diameter that work great in plain drilled holes but not in dimpled holes. Dimpled holes do end up getting stretched open slightly -- by design -- and crummy clecos slip.
I use Wedgelok clecos exclusively and have no issues. If anybody tells you to use a smaller drill bit to fix a cleco problem, ignore them!
Dan Checkoway RV-7
Old 01-31-2007, 01:44 AM
Pirkka Pirkka is offline
This has been discussed in couple of threads and here are few:
http://www.vansairforce.com/communit...ead.php?t=8874
http://www.vansairforce.com/communit...ead.php?t=7412
Also this might be the problem you are having:
http://www.planetools.com/Deburring_Holes.htm
Otherwise I would try to find proper clecos as Dan said. I bought mine from Avery and no problems so far... I haven't really tried to check which brand they are.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 01-31-2007, 06:07 AM
N520TX's Avatar
N520TX N520TX is offline
Default Copper Cleco's
I've always used the copper cleco's for #30 holes - both before and after dimpling. Prior to final drilling, they are a bit tight sometimes tho. After they got quite a bit of use, the odd one would eventually fail to hold the work after the dimple, that's when I just tossed it. I've never used nor owned a red cleco -first i've heard of that size.
Ron Walker - 40XS
RV7a - Flying
RV10 - Flying !
FFI Flight Lead - www.FalconFlight.aero
