Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #31
Old 03-29-2017, 01:36 PM
JurcaSperocco's Avatar
JurcaSperocco JurcaSperocco is offline
Very good news, as usual Garmin!
Two questions:
- What are the dimensions of the GMU 11?
- Is it suitable to install the GMU 11 into a carbon fiber wingtip?
Best regards,
Patrick
Paris, France
www.marcel-jurca.com
www.rsafrance.com
Not building a RV, nobody's perfect
2012 to 2019 dues... gladly paid!
Old 03-29-2017, 02:08 PM
RV-4 RV-4 is offline
Default NEW GARMIN GDU 460
Now if only Dynon will do the same with the Skyview SV-700 so that I can install two side x side in my RV-4..
IF not....
'' For bargain hunters, I suspect you will soon see a few GDU370's hit the classified section.''
WALT: What will be require on top of the displays to have a full Garmin system and roughly at what price ''excluding the displays',??
Old 03-29-2017, 02:19 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Two questions:
GMU 11 dimensions/weight:
2.74" W x 0.93" H x 3.49" D, 0.16 lbs
The wingtip may be an excellent place to install the GMU 11 as long as you are away from potential interference sources as spec'd in the installation manual. If you can't meet the spec, we will tell you to run an interference test to assure proper system performance.
Brian
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-29-2017, 04:22 PM
jthocker's Avatar
jthocker jthocker is offline
Originally Posted by RV-4 View Post
Now it only Dynon will do the same with the Skyview SV-700 so that I can install two side x side in my RV-4..
IF not....
Hey Thanks! Been wondering all day when there would be some silly Dynon question in a Garmin thread!!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 03-29-2017, 04:35 PM
Walt's Avatar
Walt Walt is online now
The basic LRU kit for $1500 and and the screens is all that is required to get a basic system up an running. Add the other options like AP, Xpdr, engine instruments, etc. when/if funds allow.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-29-2017, 07:48 PM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Default VFR Sectionals
Is my hope and assumption correct........ that these new screens will now support VFR sectionals as a display option?
Thank you
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2019 dues paid
Old 03-29-2017, 10:33 PM
Thumbs up G3X
Walt: Thank you for the info..
Jon'' ''some silly Dynon question''...Hey, if you don't like it, don't read it..
Bruno
Old 03-30-2017, 04:42 AM
g3xpert's Avatar
Post
Thank you
Hello Bob,
Yes, all of the G3X Touch displays, including the new GDU 470, will display VFR sectionals.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 03-30-2017, 07:17 AM
rv8or rv8or is offline
Default G5 question
G3Expert
With the new GMU11 interfaced to the G5, which will close the loop on the calc will the G5 display wind direction and strength
Rob
Old 03-30-2017, 09:31 AM
Driving '67 Driving '67 is offline
Hi Brian,
A few questions ...
Currently building a RV14, just about to start my panel. I like the thought of perhaps going with a triple screen 470 setup instead a dual 10" 460 system.
-Are the connectors interchangable? I've already got the interconnect diagram from Stein. (thinking pin callouts)
- Can the AHDRS be mounted on the back of the 470 like the 460?
- Is a GPS antenna included? (for VFR GPS built in receiver)
- Is the screen resolution the same between the 460 & 470?
Thanks Jim
RV 14A
Serial 140118
Donation - 2020 gladly done!
