Old 03-27-2017, 06:58 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Default AN509-8 R8 (MS24694) alternative?
We all know, love and swear at these good old -8 screws. Does anyone know of any better alternative? My RV-4 came with these crazy tri-wing screws. I used them and I kinda liked them, but they stripped just as easily (maybe easier). Has anyone tried Torx, hex or square head alternatives? What do you think? Are they structural (graded/certified) or non-structural (box store)?
-Bruce
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 03-27-2017, 07:27 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Torx / 6 lobe drive
These guys have torx aka 6 lobe screws: http://www.microfasteners.com/
They have stainless steel, but I would be happy to see them offer a cadmium plated option. http://www.finishing.com/136/09.shtml
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 03-27-2017, 12:31 PM
scsmith scsmith is online now
Default Careful!
The AN509 screws are structural strength screws, 125,000 -- 145,000 psi material. They are used in specific locations where that strength is important (like the gas tank attachment screws, which carry a lot of shear).
The Microfastener 6-lobe screws are great for places where structural strength is not important, like holding wing root fairings on, removable floor panels, inspection panels. Typically these locations would use AN507. But I would not recommend deviating from the plans in a place where AN509 screws are called for.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 03-27-2017, 01:12 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
These were recommended to me by a local builder but I found they galled, stripped, and even broke at a far greater rate than the AN509 screws. I ended up throwing them out and replacing them with AN hardware.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 03-27-2017, 01:54 PM
rv8ch's Avatar
Default Torx
I have not (yet) had any of those problems, and I only plan to use them in non-structural applications. It would be great to get some real AN/MS hardware with the torx head - I find torx much less likely to strip than phillips or even allen heads. I also would prefer if they were cad plated.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 03-27-2017, 03:31 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
-Bruce
Try GAHCo--They are a aviation hardware supplier and, I think, advertiser here. They've in the past offered AN/structural strength torx versions. They may even have some in stock. Usually they just need to know there is a demand. In any case, they are a great company to work with.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 03-27-2017, 04:39 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Hex Head and Phillips
These work if you don't need counter sink screws:
NAS1096 HEX HEAD SCREWS
http://www.aircraftspruce.com/catalo...ickkey=3011741
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 03-27-2017, 07:07 PM
As far as I could determine, the AN509 is the same as the MS24694 which superseded it. These are 125 ksi flat head screws.
You might try the NAS1202 screws for the #8 size, and NAS1203 for the #10 size. I couldn't find a spec on them but Aircraft Spruce carries them and advertises them as 160 ksi. That will make them stronger and the heads less likely to get messed up.
Dave
