Old 01-30-2007, 04:24 PM
N130WN's Avatar
N130WN N130WN is offline
Default Landing lights in cowling?
I'm thinking of mounting a pair of HID lights in the RV-7 no scoop cowling instead of the wing. Can anyone recommend or discourage this idea? I've only seen this on an RV-8 and didn't have a chance to ask the owner about it.
Thx.
Larry Bowen
RV-8 Built, sold, missed.
RV-7 Built, sold, missed.
RV-8 Emp in progress ...
RV-8A Purchased, flying.
Old 01-30-2007, 04:55 PM
Mel's Avatar
Mel Mel is offline
Mostly a personal thing, but I have never liked landing lights in cowling. Reasons are heat, vibration, and disconnect every time you remove the cowling. Also I think you get better depth perception with the lights in the wings. At least I do. Not to mention illuminating the back of the prop.
Just my opinion.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-30-2007, 06:51 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Just my opinion.
Same comments above from me, plus there may be some added visibility benefit of having the landing lights out some distance from the central axis of the plane. I.e., out on the wings.
2 cents
Bryan
Houston
Old 01-30-2007, 08:17 PM
svanarts svanarts is offline
The only thing I do not like about having my landing lights in the wings is the dark spot directly in front of my while taxiing at night. I've often wondered about putting a light in the cowling. I would probably want to put a quick disconnect in a convenient spot if I did something like this.
Scott VanArtsdalen
www.airprayer.net
Old 01-30-2007, 08:21 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I had a landing light in my Yankee cowling (for over 20 years...) and was constantly replacing bulbs due to vibration.....and it was a pain every time you had to pull the lower cowl. I'm really happy to have them in the wings on the -8!
(Just one man's experience...)
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-30-2007, 08:53 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default One mans experiance
I have my taxi and landing lights in my RV-6 cowl.
500 plus hours on original bulbs, disconnection is easy, after taking top cowl off, unplug connector and you are done.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 01-31-2007, 10:19 AM
kentb's Avatar
kentb kentb is offline
Default If you just are after better taxi lighting...
I would look at installing high intensity LEDs. The extra vibration would not effect them.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 01-31-2007, 06:27 PM
The high-intensity lumileds still don't seem to put out enough light to taxi by. Do you have a good source for REALLY bright WHITE LEDs? I tried LED foglights and they weren't bright at all, mostly just decorative.
Scott VanArtsdalen
www.airprayer.net
Old 01-31-2007, 07:27 PM
N130WN's Avatar
Any pictures?
Thanks, Bob.
Larry Bowen
Old 01-31-2007, 07:28 PM
N130WN's Avatar
Kent
Wouldn't HID's be almost equally durable? (filement-less, aren't they?)
Larry Bowen
