Old 03-25-2017, 03:33 PM
wirejock's Avatar
wirejock wirejock is offline
Default Cutting control cable
I need to make this control cable shorter. There's a tag saying not to pull the cable out or some ball will fall out. So how does the outer part get cut?
Is it possible to take it apart and reinsert this magic ball?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 03-25-2017, 03:38 PM
terrye terrye is offline
The silver button on the T handle operates a locking ball inside the housing (somewhere near the hex nuts). Put a cloth or pan on the bench when disassembling to catch the ball. Cut the wound outer cable, reinsert the wire and T handle and insert the "magic" locking ball as you slide the T handle into the housing. Reinstall the CAUTION tag
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 03-25-2017, 03:43 PM
YellowJacket RV9 YellowJacket RV9 is offline
I was able to cut my heater control cable (similar) without disassembly- just carefully cut off outer sheath with snips, leaving inner cable intact. Slide off sheath, then cut cable where needed.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 03-25-2017, 05:27 PM
Hornet2008 Hornet2008 is offline
I used a triangle file and just filed the outer cable. It is only a single wire and it will be done in 15 seconds.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
