03-25-2017, 10:06 AM
Proseal over Akzo?
I have searched the archives to no avail. I forgot to mask the area of my rudder where the trailing edge wedge goes before I primed. So my question is should I sand the primer off the skins in this location before I use proseal on the trailing edge or is it not necessary? I have read that Akzo will go over proseal quite well but not sure about the other way around. Thanks!
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
03-25-2017, 10:22 AM
Proseal
Akzo is pretty tough stuff. If properly prepped, it might not come off.
I think it will stick if you scuff the area well.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
03-25-2017, 12:10 PM
If you did a good job of prepping for the Akzo I would rough up the Akzo and lay it on top.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
03-25-2017, 05:03 PM
Thanks for the replies guys, that's kind of what I suspected I should do. Akzo is definitely tough stuff and don't see a problem in this area as it is riveted anyways. Just making sure it wasn't a no no.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
