Old 03-24-2017, 10:56 PM
RV-4 RV-4 is offline
Question Nutplates Part number
Hello All
I'm planning to install nutplates with my new panel that Bill Morelli at UpNorth Aviation just cut for me and I just can't remember the part number for these.
The ones I'm planning to install will be for -6 screws ( that should be small enough for a Dynon Skyview,Knob & A/P panel among others.
Does anyone of you knows the part number so that I can order the right size ??
Thank you
Bruno
rv4@videotron.ca
Old 03-24-2017, 11:20 PM
tgmillso tgmillso is offline
K1000-06 are the regular dual lug nut plates. This is probably what you are looking for.
Tom.
Old 03-25-2017, 12:01 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
I think the Dynon knob panel cutouts use a single lug nutplate.
If it's a large one, it's a K2000-06, if it's the miniature size it's a MK-2000-06.
This link give the dimensions of the large size one - http://www.tridentracing.co.uk/conte...d%20anchor.jpg
Both are at Spruce - http://www.aircraftspruce.com/catalo...nchornuts2.php
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-25-2017, 02:27 PM
Jesse's Avatar
Jesse Jesse is offline
Gil should be right here. If you call me on Monday I'll confirm that's what we use.
Jesse Saint
Old 03-25-2017, 09:32 PM
Thumbs up Nutplates
Thank you all gentlemen for the info.
I will have the panel in hand on Tuesday so I will be able to see if they are the standard or miniature models..
Cheers
Bruno
Old 03-25-2017, 11:20 PM
climberrn's Avatar
climberrn climberrn is offline
Standard 1 lug will work but USE THE SMALL 1 lug #6 plates for the AP panel and knob panel. The longer lugs will allow one of the rivets to show on your panel. The short ones are covered up by the AP/Knob panel.
As for the Skyview, standard 2 lug #6's work fine.
Joel
N626JA
RV-7A at CXP
Flying!
Old 03-26-2017, 12:59 AM
az_gila's Avatar
Smile
That is only true if you do the mounting holes.
Since the panel was CAD/CAM cut by Up North Aviation the nutplates required depend on the spacing used by the CAD program...
I'm betting you will need MK-1000 and MK-2000 nutplates.
Gil Alexander
Old 04-19-2017, 07:04 AM
recapen recapen is offline
Default Smaller sizes
Anyone know part numbers for 2-56 threaded nutplates - or even if they are made? I have used 4-40 before and I know they are available...but have some stuff that is set up for 2-56 and don't want to hog-out the countersink!
Thanks!
Ralph E. Capen
RV6AQB N822AR @ N06
"Patience"
Old 04-19-2017, 07:32 AM
rmartingt's Avatar
Thanks!
The spec exists.
MS21071L02 for one lug mini, and MS21069L02 for standard mini.
Whether you can find them anywhere is another question.
You could sort of make your own if you had to, using a tap and a piece of 1/8in material.
RV-7ER - finishing kit and systems installation
Old 04-19-2017, 08:54 AM
Thanks for the spec - they are out there for $6.98 each!
I have a 2-56 tap so I might think about making my own.
Ralph E. Capen
RV6AQB N822AR @ N06
"Patience"
