03-24-2017, 10:32 AM
Fuel tank venting
This is a general low wing question, and tho I've pinged my builders group, just wanted to see how you guys do this.
In doing my fuel plumbing for the Mustang2 (a non-EFI setup), I discovered two vent references I wasnt aware of both out of FAA-H-8083-31 Ch14. One says that fuel tanks have to have two vents (page2); the other says if tanks are y-piped together, their vents must be interconnected.
So just talking about wing tanks only (not header tank installs) my questions are:
1. Do the VANs kits run two separate vents for your wings tanks?
2. If you interconnect vents, does that fulfill the 2 vent rule above?
3. Do you need to interconnect your wing tank vents if you are running a fuel selector with "L,R Both" positions?
FWIW I've got Usher flush fuel caps which are unvented, hence the questions.
Thanks for any wisdom.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
03-24-2017, 10:45 AM
Super Moderator
The tanks on the RV's are vented separately and are not tied together. For low wing aircraft you can only have a LEFT & RIGHT, not a BOTH.
It is important to follow the manufacturer's recommendations with regards to fuel systems. Most fuel-related engine stoppage problems are due to modifications to the fuel system.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
03-24-2017, 10:50 AM
Thanks Vic. There are no recommendations on fuel systems for the M2 and therefore no standardization......or if you wish, its up to builders discretion. Hence the questions.
Mani
N251Y (res)
03-24-2017, 01:04 PM
In the 'single digit' RV's, there's a fitting on the root end of each tank, and an internal run of -4 tubing that runs along the inside top of the tank & is attached behind the filler neck.
The norm ('to plans') is to bring the line into the fuselage, then up to the top longeron, forward to near the firewall, and down to the floor mounted vent. This minimizes spilling fuel out the vent with full tanks parked on a slope, due to fuel expansion in the sun, or during acro.
A few guys (I've heard that the Rocket guys do this) have used a coil of multiple turns inside the wing instead, but that might not be as effective with the M-2's relatively thin wing.
Charlie
03-25-2017, 06:00 AM
Ok thanks Charlie. So sounds like some designs do, and some dont. Dealers choice.
FWIW, I've seen the Rocket guys coil setup and personally I dont understand why they would do that as it seems to me to be a water trap subject to freezing. I guess as long as you anticipate the limitations of such its ok, or if the coils are in some way heated like by cabin air or something so they dont experience a problem. No need to debate the issue here tho - I'm not going that route.
In anycase, can you guys or someone else shed light on if the vans setup covers the two vent per tank reference in the first post, or educate me on what it really means? Just a bit confused about that as I dont seem to see it or hear people talk about it.
Thanks again.
Mani
N251Y (res)
03-25-2017, 06:26 AM
inverted
It as has been pointed out above and is that if you are going to do aerobatics and be going inverted you need to try a keep as much fuel as you can inside the tanks when going through your positive to negative flip-flops and knife edges or dull edges if you do those too. I tell people its like a pee trap in the plumbing and it kind is. If you are thinking of putting your Mustang through its paces you may wish to look at the vent set-up in an RV-4,8,3 or 6. You should be able to find one close to you, they seam to be all over these days.
Hope this helps. Yours R.E.A. III #80888
03-25-2017, 06:50 AM
None of Van's designs that I've seen use dual vents. I suppose that having two separate non-interconnected tanks could be considered to meet the spirit of the requirement,but the early -3 had only a header tank. I don't know if it had 2 vents in it's design.
I took a quick stroll through the chapter you mentioned, & notice some other things that Van's designs might not meet, but there are also requirements that certified a/c don't meet. For instance, the requirement that
"Each tank must be isolated from personnel
compartments of the aircraft by a fume-proof and fuel-proof
enclosure that is vented and drained to the exterior of the
airplane."
The Cub & Taylorcraft are two that immediately come to mind.
These are experimentals, so we get a little more leeway, regardless of what the regs say. I don't know for sure, but I doubt that the M-2 landing gear meets FAR23. A lot of homebuilt designs' gear don't meet it.
Charlie
03-25-2017, 12:34 PM
Color me curious. I fly a friends Scottish Bulldog (low wing) airplane once in a while and it has LEFT, RIGHT, BOTH and OFF on the fuel selector. AFAIK it came that way from the factory.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
03-25-2017, 01:07 PM
Do you have a fuel system diagram? It may be that both tanks plumb to a sump (or header) tank or that they used some other workaround to solve the issues associated with a "both" setting on a low wing.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
03-25-2017, 01:54 PM
Please heed Kyle's words. Don't go modifying fuel systems unless you know EXACTLY what you're doing.
Many accidents are attributed to fuel system modifications.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
