I installed the Transpo regulator & the AutoZone alternator on my RV-4; had to fabricate an alternator bracket. Bracket: used 1' x 1 1/4" x1/4" flat stock steel; cut off two pieces 1 1/4" x 1 1/4"; welded one piece on the end of stock; bored holes in both pieces for alt. bolt(s); positioned second piece by bolting on alt; measured overall length of bracket to correspond with two alt. bracket holes and one stud hole on engine case. Measure & bore forward hole for attaching bracket, first - take your time & get that hole right. Height of two pieces to connect alt. might vary; measure carefully.
I installed the AutoZone alternator P/N 14118 on one of the retractable gear RV-4's five years ago, still going good.
CPGENERATOR.COM
12V FORD HD ADJUSTABLE VOLTAGE REGULATOR - preset @ 14.2v
Item# Transpo F540HD $26.99 USD
Shipping and handling $8.00 USD
$34.99
AutoZone Regulator also works:
http://www.autozone.com/batteries-st...30187_887935_0
Part Number: VR730 $ 23.99
Alternator/Autozone
1976 Chevrolet Truck Luv 1.8L 2BL SOHC 4cyl
http://www.autozone.com/batteries-st...34268_479962_0
Price: $35.99 Core: $10.00 Total: $45.99
Wiring as per Sam Buchanon:
http://www.vansairforce.com/communit...tage+regulator -page 1
“A readily available regulator that has seen widespread use on RVs is 1975 Ford LTD, available at your local auto parts store.
Wire it like this:
I -- no connection
A -- jumpered to "S"
S -- jumpered to "A", also connected to your alternator switch from the field CB
F -- connect to field terminal of your alternator
case -- securely bonded to ground (i.e. mount on firewall and insure good electrical bonding)”
Barney in Memphis
RV-3 & RV-4 flying
Saved by BasicMed!
