03-21-2017, 10:38 PM
bolts with low profile heads?
Where my mixture cable attaches to the control arm I've got some interference with the bolt head hitting the FAB. My solution was to simply sand down the head of an AN3 bolt by about half and that did the trick.
Now I'd like to find a "real" one (i.e., one manufactured this way) but can't seem to find anything like it on-line. Does anybody know if they make a low profile head AN3-10A and where I can buy them?
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
03-21-2017, 10:43 PM
AN23
You want AN23 clevis bolts. You can get them at Aircraft Spruce and elsewhere.
Ed Holyoke
03-21-2017, 10:52 PM
Originally Posted by Bicyclops
You want AN23 clevis bolts. You can get them at Aircraft Spruce and elsewhere. Ed Holyoke
Maybe. I'll have to check if there's enough clearance at some point in the control arm travel to get a screw driver on the head. I'd rather a bolt for this reason, however.
Phase II - 11/2017
RV-10 Build Log
03-22-2017, 04:23 AM
I wonder if a Hilock would work? There's nothing on the head to grip; the threaded end has a hex (Allen) recess so you'd use a hex bit/key and a wrench to tighten.
RV-7ER - finishing kit and systems installation
03-22-2017, 06:30 AM
NAS6203 SHEAR BOLTS ?
What about NAS6203 SHEAR BOLTS (.189" dia)? Head height is between 0.110 inches and 0.125 inches. The NAS6204 are .249 dia.
(2020 dues paid)
03-22-2017, 08:25 AM
These might work. Looks like the 6203 has the right diameter and threads. I'll verify and order a few and see. Thank you very much!
Phase II - 11/2017
RV-10 Build Log
03-22-2017, 09:20 AM
Not really,
NAS6203 head height is 0.110 to 0.125 inches
AN3 head height is 0.109 to 0.141 inches
With it being that close you might be better off just getting a bunch of AN3 bolts and measuring the heights to get one at the low end of the tolerance.
But, do you really want any control system to have moving parts with a clearance measured in 10s of thousands?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-22-2017, 09:30 AM
Joe,
If you didn't install the optional VA-131Q Recess on your FAB, would doing so eliminate the interference issue?
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
03-22-2017, 09:32 AM
Originally Posted by Auburntsts
Joe,
The recess is installed. It's the recess it's scraping. ... All I can say is that it used to fit before I put the rivets in. Very annoying, but that's another story.
Phase II - 11/2017
RV-10 Build Log
03-22-2017, 09:34 AM
Not really.
Phase II - 11/2017
RV-10 Build Log
