03-21-2017, 04:47 AM
Inspection Prep
Well the time is finally here where I need to schedule my RV10 inspection. What should I leave open for the inspector to look at? Obviously all access panels will remain open and the cowls be off, but what other areas should I make accessible? I don't have an interior other than the seats and foam which I'll probably just throw a pair of sheepskins over but all of the interior panels are still out. These will be part of the W/B but could leave them off to show how I've run conduit and control systems. Any other thoughts would be appreciated.
Jason McKay
RV-10
03-21-2017, 05:08 AM
Super Moderator
Leave the baggage compartment rear bulkhead off, the tail fairing off, the front half of the wheel pants, cowling, underwing inspection panels, wing root fairings, seats out. You want the inspector to be able to see the entire control system, so any panels blocking the view of it need to be off.
Many ask about the wingtips. I do not require those to be off.
And you will really make the inspector happy if you have some EAA technical Counselor visits documented, especially if they used a checklist or documented anything.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
03-21-2017, 05:34 AM
I just contacted the inspector and asked him what he wanted. Also asked him about flight test area and some other details I wasn't clear about. He didn't mind a bit and was very helpful.
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
03-21-2017, 05:53 AM
It is important to ask the inspector what he wants, the feds did mine and he wanted it "ready to fly". It was basically a paperwork exercise.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
03-21-2017, 06:17 AM
Thanks guys! I'm probably going with the feds as well. I'll contact the Charlotte FSDO and inquire.
Jason McKay
RV-10
03-21-2017, 08:13 AM
My experience as well. I had every panel/fairing off the plane as I has assumed (wrongly) that he wanted to be able to inspect everything. He did take a cursory look around-20 min at most. My mistake cost me a week and a return visit by this FSDO inspector once I got everything put back on just so he could see it all together before he'd issue me my AWC -- and then he had it typed up wrong so that cost me one additional day to get the typo fixed.
Moral of the story-- regardless of who does the inspection, DAR or FSDO, call them ahead of time and discuss the process so you don't suffer any surprises like I did.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
03-21-2017, 09:08 AM
Cowling on?
Did they want it with or without the cowling installed?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-21-2017, 09:34 AM
In my case, with the cowling on. He wanted it in a "ready to fly that second" condition. I'm real glad I had one of our Chapter's tech counselors, no other than Dick Koehler of EAA's "How to" video fame, come in the week before and do a final pre-inspection once over before the real thing as the FSDO guy's inspection was cursory at best.
PP ASEL-IA
WAR EAGLE!
03-21-2017, 10:14 AM
The Fed that came out of Reno wanted to see and put a hand on every control end that moved and also the engine controls. all flight control attach points, brakes, Basically everything for an annual off. also wanted to see all required engine instrumentation on the Dynon......had to point out what was what  all in all it went very well, I was very happy with this Fed inspector.
03-21-2017, 10:36 AM
Cowling installed, when he arrived I asked if he would like anything opened up to have a peek, the answer was NO.
