03-16-2017, 11:29 AM
Wingtip flexing
I finished one of my wingtips and was a little concerned about the flexibility of the large surface. I could see a flutter possibility there ie: oil canning type action. Has anyone added support inside via maybe glassing some foam ribs in maybe? Thoughts?
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
03-16-2017, 11:40 AM
I have seen some people's build logs where they install foam ribs to strengthen the FG tips. However, it seems like most were doing something else too, like installing auxiliary fuel tanks or something. I did not install anything and my tips seem fine. Check with Vans, but I don't think a little stiffening would hurt.
03-16-2017, 12:04 PM
I have a -7A but had the same concern, as the tips are pretty flimsy and folks walking by often put a hand on the wing tip, resulting in oil-canning and hairline paint cracks. I removed the wing tips and applied a single ply of 8.8 oz bidirectional fiberglass in the area of most concern. Worked great at improving the stiffness; wish I had done it sooner.
erich
03-16-2017, 01:03 PM
By all means, reinforce this area. My wing tip top is cracked from someone leaning on it at an airshows. Its gotten worse once started, by flight loads. Been waiting for warmer weather to fix. My buddy reinforced his on his initial build and his does not suffer the oil canning effect. One hopes some schmuck at an airshow will not lean their fat appendages on it hard enough to crack like mine.
Scott "Lawbreaker" (yeah, its a fair cop!)
RV-8 N710PX "Bad Attitude!"
03-16-2017, 01:42 PM
You can use 2mm Soric, a core material with a layer of 8 oz cloth over top. After sanding, just wet the inside lay the soric on, and cover with pre wet cloth. It is best to overlap an inch w/o the core, but I tested pieces that indicated little structural benefit. Make a test piece using your process first. Let me know if you need more details.
The gel coat is about half of the thickness of the 7-8 tips, don't know about the 10. quite fragile.
Use the link above, and sign up at fiberglass and you will get more discounts. They need them.
It will reduce deflection by about 8x for the same load.
Edit: Here is the test article with the 2mm core. The test piece without the core touched the bench with the same weight.
Bill
RV-7
Lord Kelvin:
03-16-2017, 07:21 PM
I never thought of doing the wing tips but i did reinforce the inside of my wheel pants and filtered air box with additional layers of epoxy, basically to fill in the weave until it was smooth.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
03-16-2017, 07:59 PM
Tips for tips
There's a great set of tips in the "Articles" section.
Opening VAF page.
Go to the left column of links.
Click on "Articles"
Download all the "Tips for Tips"
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
03-16-2017, 08:13 PM
Not to flame, but epoxy alone adds no strength, just weight. If you just want to fill in weave, use micro. If you want to reinforce, add glass.
Carl
03-16-2017, 08:18 PM
Have you screwed it to the wing? IMO, oil canning isn't a worry with it attached. The convex shape helps.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
03-17-2017, 02:49 AM
It is attached with hinges. Per the advice I think I will do a layup on the inside across the widest area to stiffen it up a bit. Thanks all for the advice and ideas.
RV10 N620RV
IO540 C4B5
Garmin G900X
