Old 01-29-2007, 05:36 PM
N941WR's Avatar
N941WR N941WR is offline
Default Items not included in any of the kits...
Just a list for those who follow.
Please add items that may be required but are not included in any of the kits.
1) Upper and Lower gear leg fairings.
2) Electric fuel pump
3) Carb heat muff & carb heat hose to air box fitting
4) Stick grips
5) Seats
6) Harnesses
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-29-2007, 06:11 PM
grjtucson's Avatar
grjtucson grjtucson is offline
Default More...
7) Aileron Trim
8) Crotch Strap Attach Hardware
9) Parking Brake
10) Static Port(s)
I stuck to stuff that, while optional, is not likely to be left off by most. I didn't put in steps, passenger brakes, or wiring conduit, those are a bit more "optional" than what is on this list so far.
George
George Jenson - http://www.georgejenson.com
Tucson, AZ - RV-7 Standard Build
Empennage Completed 1/06, Wings Completed 11/06, Fuselage Done 9/08, Panel Wiring Done 7/19. About to haul it to the airport.
Old 01-29-2007, 07:18 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default What model
I think the list is variable with each model.
Mike
Old 01-29-2007, 07:33 PM
gmpaul gmpaul is offline
Default more & more
nutplates and screws!
How ever many you think you will need extra double it you will probely still be short.
G.P.
Old 01-29-2007, 07:42 PM
bsacks05's Avatar
bsacks05 bsacks05 is offline
Bill,
I can't understand why Vans doesn't include the intersection fairings in the finish kit. Its kind of weird to get the leg fairings and wheel pants without the intersection bits. BTW The near gale force winds yesterday caused me to stay on the ground and finally make a couple stick booties. They turned out pretty good and got a thorough flight testing today.
Wow! A clear, calm and cool sky, wheel landings on grass and paved runways, and some new booty(s) after work. Life is good!
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 01-29-2007, 09:08 PM
walter's Avatar
walter walter is offline
You won't find any of these in the kit, but you will definitely need them!
(in no apparent order)
1. Determination
2. Perseverance
3. A Rivet Buddy
4. More Hours in the Day
5. A Third Hand
6. Tools
7. An Understanding Wife or Husband
8. This Website
9. The RV Community
and last but not least
10. Elbow Grease
Walter Tondu
Flying RV-8A - Fastback, IO-390, G3X Touch, 74 HRT
Prior RV-7A Build Log
Old 01-30-2007, 05:25 AM
dbuds2's Avatar
dbuds2 dbuds2 is offline
Default Not in wing kit
Proseal is ordered separate, assumes it'll take you some time to be ready.
Bud Smith, RV-8, ECI IOX360 , Dual PMags, Dynon SkyView, Whirlwind 200GA, IFR and N88ZP has "slipped the surly bonds of earth".
Old 01-30-2007, 09:45 AM
kentb's Avatar
kentb kentb is offline
Exclamation All the panel pieces
The wire for the plane.
The wire ties and attachment hardware.
Pitot tube and mount (if you want a good one).
The fiberglass stuff (cloth, resin, etc).
Sandpaper, pin-hole filler.
Primer/paint.
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 01-30-2007, 09:53 AM
PaulR PaulR is offline
Default Blank Panel?
I'm waiting on my fuselage kit and starting to plan the panel. In the catalog, Van's shows a "VFR" panel for the models that's already punched. Since that's not anything like I want, I've been assuming that a blank panel came with one of the kits. Is that not true? If not, do they give us a .dwg or a .dxf file so we can have one cut?
Probably a silly question, but I'm just wondering.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
Old 01-30-2007, 10:11 AM
bsacks05's Avatar
Paul,
You will receive a blank panel with your fuse kit.
Bruce Sacks
Warner Robins, GA
A&P
APRS KJ4EFS
