Old 03-14-2017, 07:16 PM
WingnutWick's Avatar
WingnutWick WingnutWick is offline
Default Push Starter and R Mag question
Hello!
As I wrap up my panel conversion and various other mods, I have a starter question. I had previously made a push to start system where the starter wouldn't engage with the right mag on due to no impulse coupling. I'd start with the R mag off and once the motor started just turn it on.
My question is...can I just connect the R mag to the two starter switch connections so when I depress the starter button it also closes the R mag loop (grounds the mag i.e. turning it off)?
Thank you!
Wingnut
Old 03-15-2017, 12:02 AM
Without seeing your schematic: would your proposal connect the P lead to 12 volts? And, when the starter is off, is the mag always 'hot'? This could be dangerous to anyone working on the engine and turning the prop.
Old 03-15-2017, 12:22 AM
Wunderon's Avatar
Wunderon Wunderon is offline
not sure might try asking here http://forums.matronics.com/viewforum.php?f=3
Dave Grimmer
RV8 N46LG for Lynda
Flying
Edmonds WA
paid 2019
Old 03-15-2017, 12:30 AM
It'll be hot but I also have two magneto switches to control that. Basically I took the wires fro your standard key starter. I'm thinking that it would connect the P lead and the power that runs to the starter relay?? Would this do anything?
Old 03-15-2017, 06:17 AM
Jesse's Avatar
Jesse Jesse is offline
you could do this with a double pole single or double pole switch that would ground the P-lead whenever you push the button. You would still want a switch that connected to the P-lead wire that would ground it in the off position. You definitely can NOT use a single pole switch for the start button or, like others said, you would be sending voltage to the P-lead.
Again, your P-lead would need to go to both the R mag switch and to the starter switch, so either switch could ground it.
Jesse Saint
Old 03-15-2017, 08:12 AM
That's what I figured. Unfortunately the switch only has a normally open circuit and a normally closed circuit. I would need the normally open one for both the starter and mag, so I think I have to stick with my original method of having the R mag switch off for starting.
Out of curiosity, any idea as to what would happen sending that 12V to the P lead?
Old 03-15-2017, 08:42 AM
Andrew Anunson Andrew Anunson is offline
This might allow the magic smoke inside your magneto to escape.
Old 03-15-2017, 09:02 AM
rv7charlie rv7charlie is offline
Some (well, me, anyway) would say that all that extra stuff is unnecessarily complex & adds failure points.
But if you want to do it, just add an automotive 12V relay (<$5 from multiple sources) to the circuit. Pushing the start button would apply 12V to the starter contactor, and also to the coil of the extra relay. The relay's normally open contacts would be wired across the mag switch terminals, so that when the relay is activated, the p-lead wire pair are shorted whether the mag switch is on or off.
Charlie
Old 03-15-2017, 09:44 AM
Charlie
I will heartily second this statement. Ignition is one of those things over which I want absolute positive control - that's why I went with toggle switches for the P-leads. Having flown a Grumman Cheetah for a number of years, with its "Off_R-L-Both" key switch and pushbutton starter switch, I grew accustomed to placing the key in the "L" position for starting and immediately switching to "BOTH" once the fire was lit. Doing the same thing with toggle switches is very easy since they give such positive indication of their switching status. And they tend to be quite reliable if one chooses to use the MS-type switches available from Spruce and other suppliers.
Having had a left mag fail, I can assure you that I wouldn't want anything to get in the way of the right mag working. Adding complexity would seem to defeat this goal.
Old 03-15-2017, 11:21 AM
Great feedback guys, thank you! I think I will just KISS. I was more trying to be fancy than anything else as I am perfectly capable of remembering to have the R mag off during start. I like the thinking of not wanting anything to get in the way of the R mag firing in case of a L mag fail.
Thanks guys, as always I can come here for insights and technical knowledge as I continue my learning.
