03-11-2017, 01:36 PM
FAB Fiberglass crack
Doing the condition inspection and after removing the K&M air filter I noticed that the bottom of the fiberglass section of the FAB is cracked at the rear in perfect alignment with K&M filter outline. Does not look worn through so I suspect vibration induced crack, 9 years and 460 hours. Is this something others have seen? As I will probably replace the lower fiberglass section is there something I should do to prevent this happening again?
Figs
03-11-2017, 01:40 PM
Figs
Is your filter in contact with the airbox? That might explain it.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
03-11-2017, 02:44 PM
Mine was wearing badly on the bottom of the FAB so I cut aluminum sheetto match the area of filter contact an held in place with several rivets. Seems to have stopped the problem from progresing
03-11-2017, 03:53 PM
Dave,
I just had to modify my whole air box and snout to fit my James cowl with a carb engine. It was not the easiest, but it worked as far as I can tell - not flying yet!
In my research on how to make the modifications, I saw several pictures of exactly what you are talking about. The bottom just wears out and cracks. Putting a piece of aluminum inside and re-glassing the bottom would probably work fine.
I made my box about 3/4" deeper and got the next size KN filter to give a bit more airflow. At least that is my hope.
Kyle's comment gives me a question. Doesn't the air filter need to fit tight against the bottom to keep unfiltered air from going to the carb? That is why I upsized the new filter.
[IMG]  [/IMG]
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
03-11-2017, 04:03 PM
Originally Posted by rockwoodrv9
Dave,
[IMG]  [/IMG]
No. The filter has a plate that goes on the bottom. It clears the fiberglass by about 1/4 inch or more. The air box does not seal the bottom of the filter element.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
03-11-2017, 04:08 PM
Thanks Warren. I will be back at the hangar Monday and get a few more shots.
That doesn't change anything about the OP just glassing the bottom back on does it?
rockwoodrv9a
Williamston MI
O-320 D2A
03-11-2017, 06:00 PM
Depends on aircraft model
Kyle has a 6, I have buddies that also have 6's their filters do not seal on the FAB. I have a 7A and mine does seal on the FAB and I believe another buddies 9A does also.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
03-11-2017, 06:03 PM
More proof that the -6 is the pinnacle of homebuilt aircraft development. ;-)
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
03-11-2017, 06:17 PM
Figs
Seems common - clean it well with lacquer thinner, sand it, and lay a few layers of glass in there with epoxy. I did this somewhere around the same # of hours as you, and it has held for 1100+ more hours. No need to replace the whole housing. Mine is abrading a bit wherever the filter makes contact, so I may have to add another layer sometime soon. The filter gets tortured by the intake pulses, apparently. I do not think it is general engine vibrations which cause it.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
