Old 03-10-2017, 01:49 PM
istrumit's Avatar
istrumit istrumit is offline
Default Brake Change Method ?
How hard is it to change the brake liners on a -10.
I need to with my A/P this week.
Anyone have a simple play-by-play ?
Scott
Scott Martin
N430WP RV-10 - Purchased
Old 03-10-2017, 02:45 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
EAA has a lot of good basic videos on maintenance free for members on their website. One of which is replacing your brake pads.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 03-10-2017, 02:55 PM
istrumit's Avatar
Perfect. Thank you!
Scott Martin
Old 03-10-2017, 02:56 PM
Auburntsts's Avatar
Here's the link to EAA's video on servicing disk brakes: http://bcove.me/pqf2y471
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 03-10-2017, 03:02 PM
istrumit's Avatar
If you take the brake assembly loose from the brake line, is there a trick to keep from needing to bleed the lines ?
Scott Martin
Old 03-10-2017, 03:10 PM
rvbuilder2002's Avatar
No. (actually there is but I only use it in an emergency)
If care is used, there is no need to disconnect the solid line.
Scott McDaniels
Hubbard, Oregon
Old 03-10-2017, 07:34 PM
Jesse's Avatar
Jesse Jesse is offline
1. Remove the wheel pants.
2. Remove 2 bolts holding caliper halves together.
3. Remove and replace lining on wheel side.
4. Carefully remove caliper from slide rings.
5. Remove inboard lining plate from caliper and replace linings.
6. Reassemble in reverse order.
The main problem is that dirt/brake dust in the piston on the caliper can cause the o-ring to leak. If you can clean that, or if your linings aren't too far gone, then you may not have to bleed the brakes again.
Jesse Saint
