03-10-2017, 10:57 AM
Precision approach speeds w/FP prop
As a new instrument pilot, I am trying to develop routines that will serve me well. Most of my approaches in training were low approaches without many landings (probably a flaw to avoid for others - I should have been doing T&G's occasionally). I have a 6A with a FP prop. I flew most of my approaches around 95-100 Kias and liked the stability afforded at this speed. I have no problem slowing down to flap speed on the non-precision approaches. However, the ILS and LPV's are different.
The other day I did a practice LPV to test my new 430W. I decided to do a T&G and at 250' I tried to slow down an add flaps. That wasn't going to happen without leveling off for a bit or slipping it (probably don't want to do that with 200/1  ). During my training, I just planned to land long without flaps on the ILS', as most have longer runways and wouldn't be an issue. Now that I have Waas and LPV's, I could be shooting approaches to 250' on shorter runways. I admittedly haven't gone out yet to figure out what I can realistically do to lose speed in this situation. That is the plan for this weekend.
I have read quite a few posts here about slowing down and adding flaps once the runway is made. However, I suspect most of these folks have CS props. I like the stability of the faster approaches, but I need a plan for when I expect to pop out at 200 or 300'. I am wondering what others with FP props do. I am thinking that I will need to slow down to 80 Kias and add flaps when I intercept the GS when I am expecting a low ceiling.
Thanks in advance for sharing your experience here.
Larry
03-10-2017, 11:20 AM
I don't know what your approach speed with flaps so that makes a difference. In my airplane with a FP prop I set 10 degrees of flaps at 85KIAS before the FAF. Then use power to stay on the glideslope all the way down. I do this on all approaches so I know how it is supposed to act without having different settings. Lessens the chance that I make a mistake.
If I break out early I can add flaps if needed. If I don't break out til mins I can land it without changing configuration. If I have to go around I don't have too much flaps to be a major concern.
YMMV
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
03-10-2017, 11:24 AM
I fly the -9A st 90 knots so that flap speed is only 3 knots away. I have no problems slowing to flap speed, then full flaps, then 70, all at about 500'. That's what I do. On the other hand, you want to get everything taken care of before the glideslope gets real sensitive farther down.
Go see what works for you. Try a 70 knot approach and get good at it, even if you don't like it, just because. Be able to do everything because some day it might come in handy, regardless of what you prefer.
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
03-10-2017, 11:54 AM
85-90kts
on approach. I'm with Galin on this. get 'er slowed down prior to the FAF and put 10 degrees flaps in. makes for a very comfortable approach with plenty of stability - I like the feel of the plane better than the same speed with no flaps in approach mode. also lessens the workload when you do break out on short final - just add flaps reduce power and land, no worries.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2019 =VAF= donor
03-10-2017, 11:59 AM
Speeds
I fly 120 knots until a mile from the final fix then slow to 110 and add 10 degrees of flap. As it slows down to full flap speed, 88 knots, I add full flaps and add power at about 500 feet for 70 knots to minimums. RV 8 fixed pitch.
03-10-2017, 12:03 PM
+1 for Ed.
I agree with Ed, in that a safety pilot and a lot of different practices will get you ready most arrivals. Don't be afraid of 70Kts. or above to flap speed. And if you are landing on an ILS runway and stay on the slope you should have plenty of runway with even no flaps. Try it with the blinders off. It is just a longer roll out, but not much even at 80Kts. You can put the speed breaks out after you touch down.
Yours, R.E.A. III #80888
P.S. If you have an "A" you can also keep as much pressure pulling the stick back as will just keep you on the ground until you get just under flight speed, then keep it all the way back. This to will slow you down faster than you may think.
03-10-2017, 12:19 PM
Ed
Do you do all of this at 500 AGL while on the GS? Or is this after you break out of the clouds and setting up visually?
Larry
03-10-2017, 01:32 PM
look out above
the nice thing about already having slowed is, well, you're already slowed.
one of my early IFR flights in the RV involved a 120 kt no flap descent on the glide slope to a cloud deck at 6 or 700'. figuring 120 kts wouldn't work too well on landing in my -6, I went power to idle and pulled the nose up a little to bleed some speed.... yep, right back into the clouds. probably a dozen ways that scenario could go bad. the missed worked out okay, and was good practice, but I wouldn't want to do that at 300-400'. with a fixed pitch prop you really have to plan ahead for airspeed reduction.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2019 =VAF= donor
03-10-2017, 02:01 PM
Thanks for the ideas and suggestions here. I'll go practice some LPV approaches, in VFR, at 95-100 MPH, with and without 10* of flaps. I'll try taking that all the way to the runway, as well as trying to add more flaps.
Larry
03-10-2017, 03:17 PM
Key word: Be stabilized
172: in every type of aircraft and approaches the key word is to be stabilized...
You don't wanna start lowering flaps or gears ( as the case may be ) below 1000' AGL.
In the Airline world ( at least mine :-) ) IFR is to be stable by a 1000' AGL, VFR 500' AGL...This means to be on speed with flaps (if required) & gears down...
If unstable....Go Around & try again...
It also depends where you're landing at...O'Hare will be different than your local airport..
Landing at major airport it is a good idea to tell the approach controller at what speed you plan on flying your approach so that he can plan accordinly with the guy behind you..(I do this in Paris as they will always sequenced us behind a A-319 or an AVRO 146 who's flying the approach at 120 kts while we're at 160 with everything down..
Good luck and keep on flying IFR, Best way to learn the system..
Bruno
