I have used piano hinge with great success. However I found in a few problem areas I used a different approach from stock.
One: I used stronger forged piano hinges that are solid and don't have burrs. Notice the lighter weaker rolled hinges have small burrs in the high stress corners. Consider smoothing the edges of all hinges before installing to reduce this stress concentration. They can be rough and is no wonder they crack.
The second approach is to consider counter sunk screws and nut plates vs. the expensive quick release hardware. With an electric screwdriver and limited use in a few places, this is a cheap and effective solution.
The only place I went away from the piano hinges completely was behind the spinner, where I used screws and nut plates. They are a little more of a pain to remove, but with an electric screwdriver and the lower cost it is something to consider. Also I am talking about limited use in combo with piano hinges. I used a metal reinforcement, 3 nut plates, screws and tinnerman washers on each side. Piano hinges are too weak. Again just 6 screws can be removed very fast, even by hand tools, sit flush and are cheap.
Except for the spinner, I found the standard hinges work well except for the lower aft cowl to firewall side piano hinge. I had cracking problems, ie failed lugs. The pressure inside the upper cowl, plus the external air load on the lower cowl really puts a large prying load on them. The solution was to use heavy-duty forged piano hinges. The problem went away. These solid forged hinges are awesome. They cost a little more but still cheaper than quick release hardware and I think looks better.
The last area was the aft upper cowl to firewall piano hinges. Not a strength issue but they are a pain to install thru the oil door. I still used the standard hinges but used a little flap door held with one screw in the center to access the pins from the outside, making installation easier. I would consider screws in this area next time.
The last problem with hinges is the rivets working loose. You should consider the hinges in the cowl are bonded on. Drill little weep holes in the hinge flange to allow the epoxy to flow. Cleco and clamp, than rivet. Make sure the rivet pitch is not too large and make sure you have good grip lengths and slightly over drive. So not to distress the fiberglass consider a squeezer or back driving.
Cheers George
