Old 03-07-2017, 07:28 AM
pa38112 pa38112 is offline
Default Bearing failure
About 3 weeks before my condition inspection I started hearing a rumble that told me I might have a main bearing going bad. I decided to remove the wheels and inspect them prior to the condition inspection to know how many bearings to order. Sure enough, I found an ever-so-slight water mark on the left outboard bearing. I re-packed all of the bearings and reassembled, planning on replacing the bearing during the condition inspection. I had 7 landings total between then and the condition inspection. I was amazed at how bad the brand new grease looked in that bearing after only 7 landings. The grease in the other bearings all looked new. See photo:
https://photos.google.com/search/_tr...8OsFhAZknoeGpM
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 03-07-2017, 09:11 AM
johnbright's Avatar
johnbright johnbright is offline
Originally Posted by pa38112 View Post
FYI photo link does not work. "The requested URL was not found on this server. That’s all we know."
John Bright, RV-6A 25088, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDSEFI EM-5-F
Schematic and other electrical related files
Instrument panel CAD jpg images
Construction Photos
Newport News, Va
Old 03-07-2017, 10:10 AM
PerfTech's Avatar
PerfTech PerfTech is offline
....You could send in your wheels to us when you do your annual to
have us do the bearing mod, true and balance. At that point you will
never need to repack, replace or concern yourself with wheel bearings
again. Thanks, Allan....
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 03-07-2017, 04:11 PM
Rstansley Rstansley is offline
Default Cost
How much do you charge? I have an extra set of wheels I might send to you.
Richard Stansley
Sylvania, Ohio
RV 4
Old 03-07-2017, 04:33 PM
PerfTech's Avatar
....Pricing depends on services you would like
(Tire, tube, truing, balancing, Etc.) Go have a
look at our website and watch the video and
see what you think. Thanks, Allan..
Allan Nimmo
AntiSplatAero.com
RV-9A / Edge-540
(909) 824-1020
