Originally Posted by cajunwings
The governor is well above the oil level in the sump so no worries there, but there is oil in the governor and the line that goes forward to the prop so you will be dealing with about a cups worth. If you are only removing the governor unbolt it from the drive pad and leave the drive pad bolted to the rear case.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Except if it is a dual mag system. The drive pad is integral to the pump.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
