Old 01-28-2007, 07:10 PM
decathlon737's Avatar
decathlon737 decathlon737 is offline
Default Newer spars for RV-8 Wings
Can anyone tell me when the newer spars were released in the RV-8. Trying to decide on purchaseing an older project. Thanks in advance.
Decathlon737
Old 01-28-2007, 07:19 PM
RV8N RV8N is offline
I don't know the answer but I have the original spar and have no issues with it. If I was in the market for a project, I would be more worried about the quality of workmanship already done.
Karl
RV-8 #80240 SOLD
1999 BMW R1100RS
Old 01-28-2007, 07:28 PM
mannanj's Avatar
mannanj mannanj is offline
Default Spars
Spars were changed at some point around 99 or 2000 I think. Not much, but the earlier ones are limited to 1550 lbs. for aerobatics and the ones after serial no. XXX upped to 1600 lbs. Not a deal breaker if the price is right. Call Van's and they can tell you when and where the serial number change occured.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 01-28-2007, 07:53 PM
AX-O's Avatar
AX-O AX-O is offline
I had the same question. Van's told me the new spar came out in 2000.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 01-28-2007, 09:36 PM
Low Pass's Avatar
Low Pass Low Pass is offline
I still fly my plane with confidence (original spar design), but it was no wonder to me that the weak point is where it is. A spar cap, skin joint and control surfaces all terminate near this point of concern. Extending the spar cap another 10-12" sure makes sense. Which is what I believe was done. Having the new design wouldn't be a deal killer to me alone. Would factor in somewhat though. Overall workmanship is the key, IMO.
2 cents
Bryan
Houston
