Old 03-03-2017, 09:21 AM
JonJay's Avatar
JonJay JonJay is offline
Default Ring Terminal Failure / Impromptu Terminal Test
A Hot Mag led me to two broken ring terminals which had failed simultaneously or close to it. Both the shield and P lead where broken off. With the recent discussions on terminal quality, I thought it would be a good time to do a very unscientific field test.
The terminals gave out on the right mag at about 700 hours. Inspection of the left mag terminals under magnification showed cracks in the plating and it didn't take much, a gentle push, and both of those terminals failed, so they where ready to go at anytime.
The terminals in question where from Vans standard wiring kit. Let's call those Average Quality Terminals. Although it had been many years, I still had some of these terminals from a wiring upgrade. I also had terminals purchased from a high end electronics shop (I will follow up with the brand). Call them Good Quality Terminals, and terminals from B&C terminal kit that I purchased for maintenance use, High Quality Terminals.
The test was simple; Crimp a wire onto the terminal. Grab terminal with pliers. Bend up and down approx. 45 deg. and see how many cycles before failure. Very unscientific.
The difference was striking. The Average Terminal only made 4 cycles and they "snap" off. The Good, 8 cycles. The High Quality from B&C, more than 20! As you can see in the videos, there is an obvious difference in temper. The B&C terminals (whatever brand they use in their kits) start to plasticize well before they break. They break without the "snap".
I am not a scientist or engineer, so please take my rudimentary stupid field test with a grain of salt, but for me, it proves a point. There appears to be a big difference in the performance of these different terminal connectors. It may not matter in many applications, but for Mag wiring, a high vibration area, I doubt I would have had a terminal failure at 700 hours if the connector quality had been that of the B&C or even the Good quality product.
http://https://vimeo.com/206580273
http://https://vimeo.com/206580379
http://https://vimeo.com/206580412
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-03-2017, 09:41 AM
BillL BillL is offline
Excellent practical test, Jon! B&C or Stein - both excellent. The big companies would fasten a 2-3" wire, fasten it to a shake device and let it bend itself.
The difference is striking and quite believable.
Bill
RV-7
Lord Kelvin:
Old 03-03-2017, 09:46 AM
JonJay's Avatar
It the difference is striking and quite believable.
I thought of setting something up, but with the average terminal still making 700 hours, and not knowing how I could make a fair accelerated test, I just didn't want to commit to it.
I think I am just proving the obvious, but perhaps this will help someone not have a hot mag issue due to a failed terminal. Unless Vans has upgraded the terminals in their wiring kit, I wouldn't use them for Mags.
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-03-2017, 10:05 AM
johnbright's Avatar
johnbright johnbright is offline
Default Ring Terminals
Thanks Jon. IMO your bend test is very meaningful.
I can see why magnetos are designed failsafe to a broken ignition switch wire.
I plan to use only Amp or Molex brand terminals as mentioned in Bob Nuckolls'"Anatomy of a Good Solderless Terminal Connection".
Crimp tools are critical of course. I purchased off EBay the Amp tool in "Bob's Shop Notes: Chevy vs. Cadillac Crimp Tools".
John Bright, RV-6A 25088, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDSEFI EM-5-F
Schematic and other electrical related files
Instrument panel CAD jpg images
Construction Photos
Newport News, Va
Old 03-03-2017, 12:47 PM
DanH's Avatar
DanH DanH is online now
No much excuse for broken terminals on a Slick, even cheap terminals. All it takes to be sure is an Adel on the ground screw.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-03-2017, 01:02 PM
JonJay's Avatar
Published somewhere? Looks like a good idea but I haven't ever seen it in use.
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-03-2017, 01:21 PM
N941WR's Avatar
N941WR N941WR is offline
The same thing goes for the P-mag connectors.
Add enough layers of shrink tubing over the wires so the Adel clamp keeps the wires from moving.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-03-2017, 01:22 PM
DanH's Avatar
Here on VAF, and in Kitplanes.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-03-2017, 03:07 PM
JonJay's Avatar
Thank you. I will incorporate the next time the cowl is off, although a cheap terminal lasted 700 hours, I am sure the better terminals will outlast me.
I always get a little nervous adding something to an engineered piece of equipment. Tiny screw holding a tiny terminal now holds a clamp, but this seems more than reasonable. Thanks again.
Bucker Jungmann
RV1 - Proud Pilot.
