Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
  #51
Old 03-31-2017, 07:42 AM
DanH's Avatar
DanH DanH is offline
Let's focus...the point is that the sump is only one component in an assembly of components. Every component in the assembly contributes to variance, not just the sump. It's not reasonable to blame one piece alone, or claim perfection for any, including injectors.
Digital injector trim? Yep, no question, the absolute best new development in EAB fuel delivery. Regardless of where the variance comes from, it can be corrected from the cockpit, in moments.
Originally Posted by Norcalrv7 View Post
It appears in this style sump, the intake tubes normally extend into the sump to form the bell mouth tubes. My intake tubes (made by Vetterman) end after the 0-ring seal.
Tell us more about those Vetterman tubes. Got a photo?
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-31-2017, 08:02 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
If I recall correctly, there was an old thread about the bell mouth tubes being installed in the sump, and swedged into place---the guy was looking for the tool to redo the swedge---the internal tubes are effectively a part of the sump, and the tubes running to the heads are separate units.
It is not clear in Dan's image, but the way it looks is like the tube is one continuous piece from bell mouth to the head? Uses a thick wall seal that takes up the extra diameter needed for the bell end to pass through the sump casting?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-31-2017, 08:23 AM
DanH's Avatar
That's correct Mike.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-31-2017, 08:39 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
In the case of Dave Anders, he had the best stuff he could get on there- flow matched heads from Lycon and a Sky Dynamics intake which follows best automotive practice with a large plenum and tapered, near equal length runners. Even then, we saw variations of a few percent. Compare that to Clark Carrol's roughly 10% max variation. Most combinations are somewhere in between those two sample points. If we strip away each variable one at a time, it seems to me we are left with one conclusion- airflow imbalances exist in these engines to varying degrees due to intake design and port flow differences. We know which variables can contribute to imbalances but without more experimentation, it will be hard to zero in on what is the ultimate combination for a particular engine.
I'm keen to see what Mike's back to back comparisons show.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 03-31-2017, 08:40 AM
Toobuilder's Avatar
The 540 and 360 "tuned" sumps differ in that the six banger indeed has the tulips swaged into the sump, whereas the four has one piece tubes from head to tulip.
And yes, Dan, the sump is but one aspect of mixture distribution, but it can be a big one. These "tuned" sumps from Lycoming seem to be taylor made to take advantage of modern EFI and with their big plenum area and tuned runners actually predate the design of automotive EFI intake manifolds by decades.
I believe that Caleb is likely leaving power on the table with the truncated induction tubes he's running. I intend to test that theory with my airplane by experimenting with induction tube length as a means to find optimal VE, but again, I need to get the thing in the air first. That said, Lycoming probably got pretty close with their original design and cutting several inches off the tulips is most certainly going to change tuning. It likely shifts the optimal power range up and out of the normal RPM range we normally fly with.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 03-31-2017, 08:58 AM
Mike S's Avatar
Senior Curmudgeon
Your are forgetting about the scavenging or restriction that the exhaust system can create in each cylinder. Especially for a NA engine.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 03-31-2017, 11:04 AM
DanH's Avatar
In the case of Dave Anders, he had the best stuff he could get on there- flow matched heads from Lycon and a Sky Dynamics intake.... Even then, we saw variations of a few percent.
Interesting. You're saying even Lycon and Sky Dynamics can't can't really balance airflow. Probably true, and I'm not surprised. It's a dynamic system.
Re Clark's 10% variance; IIRC he was using an updraft sump, swapped it for an updraft sump from a different manufacturer, and recorded no change. Should we conclude that sumps make no contribution to variance?
Na. I'd still say it's a combination of random contributions from every component, and be pleased that you've developed a way to trim it easily.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-31-2017, 02:20 PM
Toobuilder's Avatar
...Re Clark's 10% variance; IIRC he was using an updraft sump, swapped it for an updraft sump from a different manufacturer, and recorded no change. Should we conclude that sumps make no contribution to variance? ...
I think its reasonable to theorize that the manufacturer of a PMA'd sump will share the gross charactaristics of another, similar design. Most of those updraft sumps share the same choke points. The change to the "tuned" design however represents a significant departure in design. Its as compelling as the difference between the Ford 302 intake of 1970 vs 1990.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 03-31-2017, 04:19 PM
rv6ejguy's Avatar
I think we've covered the many variables which can affect jug to jug airflow variations numerous times before, including exhaust. If you don't have equal length exhaust primaries, chances are that different jugs will "pipe in" and "pipe out" at different rpms leading to improved or degraded scavenging compared to the next jug.
I agree with Toobuilder, sumps with nearly the same design are likely to work similarly no matter what name is stamped on it.
I'd be interested to know how close the primary tube length is on Dave Anders RV4 are since he's got the other bases well covered.
The nice thing about having SDS on an engine is we can easily quantify AFR variations which give quicker results from experimentation.
BTW, auto racing engine designers understood and implemented tuned length intake systems at least 2 decades before Lycoming came up with any of their better designs. https://ixquick-proxy.com/do/spg/sho...cf5b9fcd00472f
Old 03-31-2017, 05:30 PM
rv7charlie rv7charlie is offline
Default Lyc had them that early?
https://en.wikipedia.org/wiki/Chrysler_B_engine
That was in production cars, and I'm pretty sure it wasn't the 1st. Racing, obviously much earlier than that.
