Thanks for the help guys. It's what I suspected after lots of looking through the drawings and plans. I'll just try to go slow and take off the least possible. Today my big chore is to figure out how to drill the first mount hole in the firewall. When I put the mount up on the firewall, all of the predrilled 3/16" holes in the firewall are off by about 1/32+ compared to the mount holes. I guess I just try to split the difference on all of them? The instructions say to square the mount to firewall, but how do you do that? What does "square" mean in the context of a welded mount? There's not a straight line on it to determine what's square!
Originally Posted by mburch
Steve, I think you and I must work at the same pace - you are always either a couple weeks ahead or a couple weeks behind me.
Got you confused about my building pace, don't I Matt?! Actually since I picked up the finishing and FWF kits in late Nov. I've been skipping around a whole lot between the two kits. I did all the rollbar fitting first, but I'm really at a standstill on the rest of the canopy because it's too cold to cut. It seems like I go out into the garage each day and spend half my time just figuring out what do that day. From here on out it seems like I'm on my own to decide what to do in what order. More days than not it's been little things like drilling a hole in the firewall, or installing a gascolator, or going back a replacing a few rivets on the back of the fuselage, or trying to figure out how to drill for the engine mount, etc. etc. I still use your website fairly off so make sure you stay ahead of me! Good idea on the pvc pipe stand in for the gear legs.
Thanks again to all.
