Old 02-24-2017, 12:48 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default alternator balancing
Is balancing the alternator a thing? The reason I ask is that I have had to add a couple of big washers under my 4" pulley for spacing, and want to make sure I'm not inducing an unnecessary vibration.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 02-24-2017, 12:58 PM
rv7charlie rv7charlie is offline
It does need to be balanced, but if the washers are a snug fit on the shaft (centered), it wouldn't worry me.
However... having played around with a lot of different automotive alternators, adapting them to a/c engines and to other auto engines, I'd look carefully at the retaining nut, to be sure it still has adequate 'bite' on the shaft threads. Many alternators don't leave a lot of wiggle room for anything other than 'stock' thickness pulleys.
FWIW,
Charlie
Old 02-24-2017, 02:30 PM
rv8ch's Avatar
Default cheap hardware
Thanks Charlie. The 4" Summit pulley is about 3/16" thinner than the original, which is why I added 2 washers close to the alternator, and one close to the nut. There are plenty of threads.
The washers didn't seem like they had a lot of precision since they are cheap hardware store items, thought I'd check on the balancing.
Perhaps I should find a better source.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 02-25-2017, 02:48 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Find someone with a lathe and turn a pair of spacers out of aluminum, since the pulley is alum too. That way, they will fit the shaft perfectly and no worries about balance. Plus, you could fine-tune belt alignment through spacer thickness if desired.
Heinrich
Old 02-25-2017, 07:51 PM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
When you are doing your prop balance you can see the alternator peak show up on the vibration spectrum. Make sure you do it on a balancer that can show you the full spectrum.
To find the peak just calculate the rpm from the size of the pulleys. Mine spins at 3.61 x engine rpm.
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 650 hrs
OnSpeed development team
