I did not use any reinforcing strip to secure the aft window (tipup) to the roll bar, just the screws. I did lay the aft (thinner ) edge of a "P" seal under the plexi to provide a seal for the canopy as it layed on the roll bar. No problems in three years.
I had no problem securing the wheel pant brackets without spacers. I would be careful using spacers as you could encroach on the wheel clearances.
Go at least 1/2" on the sides and 3/4" on the fore and aft openings for adequate tire to pant clearance.
Hope this helps. Worked for me.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
