Old 02-22-2017, 07:54 AM
rvsxer rvsxer is offline
Default GPS derived TAS Calculator
We all want to know how accurate our airspeed indications are, don't we? Well for a long time Kevin Horton had a link to a website (REA Computing) that had one which, if I remember correctly, he said worked pretty well. You fly 3 legs, with headings 90 degrees apart, at the same IAS, and record your TAS and the 3 GPS groundspeeds. Plug the groundspeeds into the applet. The result should be your "true" TAS.
That website quit working for me but here is another:
http://www.csgnetwork.com/tasgpscalc.html
The complete instructions are on the webpage. I am sure the spreadsheet type TAS calculators are more accurate but this is a lot simpler. I welcome any comments as to the accuracy of these applets from any of you "aeros" out there.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 02-22-2017, 09:16 AM
titanhank's Avatar
titanhank titanhank is offline
I just plugged in my latest numbers from a 4 way gps run and the tas was within .5 mph of the 4 way average.
Rv-6
0-320/180+hp
10-1 pistons
Lycon port/polish
Dual pmags
EI Commander
Whirlwind 200rv prop
IFR Glass panel
Trutrak Vizion 385 Autopilot
Flightline Interior
Almost rv14 seat mod/cable locking
Electric seat back adjuster
