Old 05-08-2005, 06:33 PM
uk_figs's Avatar
uk_figs uk_figs is offline
Smile AN Nut and Bolt guide
Just a quickie, anyone know where I can get a guide for AN nuts, bolts, washers etc. Wasted time today trying to figure what a AN960-10L washer was (found out it means a thin washer).
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 05-08-2005, 06:48 PM
Captain_John's Avatar
Hahahaha, I just went through that scenario!!!
Doing the bellcranks, huh!
Ummm, well... what helped me out was the Spruce website, talking to builders and the Standard Aircraft Handbook. Between those 3 resources, I have learned enough to be dangerous!!!
I haven't found a single site that clearly defines, "this is a bolt, and this is a nut."
What also helped was buying a few extras for assembly use. Get a gauge too. They are handy and sets you mind to ease knowing that you have the right bolt.
Any specific questions? I will try and help, but remeber... I am only one step ahead of you! Keep 'em easy!
OH, and have fun doing that flutin'!
You got your work cut out for you!!!
Mine only took a month!
CJ
The experiment works!
Old 05-08-2005, 06:49 PM
rv6builder48138 rv6builder48138 is offline
Default Guide for AN nuts, bolts, washers
Dave: try this web site...
http://www.zenithair.com/kit-data/ra/hardware.html
John
Old 05-08-2005, 06:52 PM
Default Another guide
Here's another one, even more detailed:
http://www.spenceraircraft.com/catal..._cat_pages.php
John
Old 05-08-2005, 06:53 PM
Default And straight from the FAA...
http://www.faa.gov/certification/air...13/default.htm
Old 05-08-2005, 07:10 PM
Prepping wing ribs? Man, that STILL is the LEAST fun I've had on the entire project.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 05-08-2005, 08:05 PM
N941WR's Avatar
N941WR N941WR is offline
Default Just be thankful...
you're not building a -9! Same number of ribs but a lot more rivets and those flaps are a major PITA!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-09-2005, 08:33 AM
uk_figs's Avatar
Cool AN guide
Thanks for the links (and the thoughts about prepping all those ribs) :
Dave's RV-7 Blog
Email me
Old 05-09-2005, 11:02 AM
flyerfly flyerfly is offline
Default Good links
I too spent hours looking for some of this stuff (for wiring) just yesterday. These links (the ones John had) would be good to have in a permanent resource place. Also most of the FAA docs can be downloaded in PDF format if you like those.
Jon
"They who can give up essential liberty
to purchase a little temporary safety,
deserve neither liberty nor safety. "
- Benjamin Franklin
Old 05-09-2005, 01:06 PM
kellyp kellyp is offline
Default AN hardware chart
Best guide that I've found:
http://www.matronics.com/photoshare/...om.01.18.2003/
Whenever I have a "what the **** is that?" moment I can look at this chart.
Kelly Patterson
200 hours
RV-6A N716K
Parker, CO
